Post new topic Reply to topic  [ 1449 posts ]  Go to page Previous  1 ... 29, 30, 31, 32, 33, 34, 35 ... 97  Next
Armyforge Update (Online EA Force Creator)
 Post subject: Re: Armyforge Update (Online EA Force Creator)
PostPosted: Wed Aug 07, 2013 11:17 pm
Ahem, The BHGS Britcon committee do all the hard work, I only have to herd 8 Epic players!
Though noting will be happening to the end of next week most likely.
@MephistonAG for all sorts of twitter madness
PostPosted: Thu Aug 08, 2013 2:03 am
Anyone want to set me hip to crafting some files for this? Haven't heard back from anyone regarding this so going public :)
:sos :sos :sos
If it's EpicUK lists then Mephiston & Kyussinchains can sort you out.
If it's NetEA lists then PM Parintachin and hopefully he will sort you out.
An online epic force creator:
Armyforge
PostPosted: Thu Aug 08, 2013 3:36 am
PostPosted: Wed Sep 11, 2013 12:59 am
Not sure if this is the best place to post, but the NetEA/Harakoni Warhawks list has been returning me a javascript error and refusing to load. Multiple computers, running Firefox, for at least a month now. Don't know enough about the app to know if it's the file or the parser.
PostPosted: Thu Sep 19, 2013 12:15 pm
I can try to look at that sometime.
The NetEA Tau list needs some updates too.
PostPosted: Thu Sep 19, 2013 1:56 pm
The Space Marine Tactical Land Raider option and 3 x overcosted Skitiarii in the TL list could do with being fixed (plus the other new changes to the TL costings).
I understand Adam has other things going on and that's fine, we really appreciate the work he's done, but if others could step up and keep the lists updated that would be great.
PostPosted: Thu Oct 03, 2013 3:05 am
In the White Scars list for Landspeeders, it only lets you swap out a max of 2 units for Typhoons. According to the compendium that it is based off, you may "Replace any number Land Speeders with an equal number of Typhoons".
PostPosted: Thu Oct 03, 2013 3:07 am
Sounds like a cut-and-paste error from the main Astartes list.
PostPosted: Thu Oct 03, 2013 4:32 am
Try PMing Parintachin
(if he's not responding then we can look at adding another maintainer...)
Armyforge
PostPosted: Thu Oct 03, 2013 6:34 am
I'm here; looking at it now.
Fixed the Typhoons in the file. I can't see it working when I access the builder. Is there a cache somewhere, or does it need to be approved first? Works offline.
Let there be code.
PostPosted: Thu Oct 03, 2013 7:03 am
good stuff, just let me know when you want an update and i'll push to the site...
Armyforge
PostPosted: Thu Oct 03, 2013 7:12 am
Go ahead.
Let there be code.
PostPosted: Thu Oct 03, 2013 7:14 am
How are you on updating lists to fit the latest versions? Should I plunge in and do them as I see fit, do you want a certain order or do you want bugfixes first?
Let there be code.
PostPosted: Thu Oct 03, 2013 8:12 am
up to you, so long as the version identifier is correct
Armyforge
PostPosted: Thu Oct 03, 2013 8:17 am
site updated :)
Armyforge
