Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 81 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
6mm terrain suitable for Epic
 Post subject: 6mm terrain suitable for Epic
PostPosted: Tue Aug 31, 2004 2:35 pm
I too am thinking about bikes rather than horses for my RRs.
I can understand how there might be a use, for example it would allow covert forces to move great distances without re-supply, living off the land.
But then I would hope by then that bikes would be electric powered and solar cells would be used to re-charge batteries (if required - I'm not an expert, but once moving, can batteries not be re-charged as you go?)
If using bikes, would you still use the basic RR stats (for E:A)?
Furgie
PostPosted: Tue Aug 31, 2004 3:16 pm
I use both IG Bikes & R/Riders in some of my IG Rgts.  The Chinese were using horse Cav as late as 1979.  I also have the option in my IG Cav to deploy them on bikes or horses. We also kept the SM1 rules giving you the option to dismount. Using horse mounted troops not as tradional Cav but as "light horse", ie.- infantry mounted on horses for transportation.  Of course we still have the ability to use them in a Cavalry Charge.  I took on some Khorne Juggers like that once !  And remember my and Jervis's contention that Epic is a high tech version of WWII. The Germans and Russians (Cossacks) used Cav throughout, but as "light horse".   Just some thoughts ... (of a sick mind) ...    :;):
PostPosted: Tue Aug 31, 2004 4:38 pm
Quote (vanvlak @ 30 2004 Aug.,23:30)
"The Marine bikes have a smooth drop off and ..."
Gulp! An extract from Dafrca's twenty-four volume 'Taxonomy of bikes and jetbikes of the early 41st millennium'
:laugh:
              - Cities of Death, page 59
PostPosted: Tue Aug 31, 2004 4:41 pm
Quote (furgie @ 31 2004 Aug.,06:35)
[snip]
I use bikes in one of my RR squads. When I use them I just use the stats for the RRs as they are and invoke the "use as" rule.
So far no one has seemed to care. The stands are the same, the stats are the same, and it isnot like someone would mistake them as anything other then what they are.  :D
dafrca
PostPosted: Tue Aug 31, 2004 4:44 pm
Quote (Legion 4 @ 31 2004 Aug.,07:16)
So when you dismount them, do you have markers or replace them with normal stands or what?
I have wanted to do some stands with horses and one handler and stands with troopers on it just for fun.
dafrca
PostPosted: Tue Aug 31, 2004 5:42 pm
I always thought that was one of the coolest rules in AT/SM1, permiting mounted infantry to dismount. We had a lot of fun with that rule! :)
PostPosted: Tue Aug 31, 2004 6:21 pm
Quote (primarch @ 31 2004 Aug.,09:42)
Did you model them any different or just treat them as having Infantry stats?
dafrca
PostPosted: Tue Aug 31, 2004 6:44 pm
I want to convert some Chaos lizards into IG proxy cavalry in the future. The 28mm 40k IG Codex has illustrations of IG lizard riders.
I loved the guy who cut apart RRs on Tuffskull's site and made them into lizard riders.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Tue Aug 31, 2004 9:35 pm
Personally I used to just substitute them with infantry stats with standard stats for infantry.
PostPosted: Wed Sep 01, 2004 5:30 am
I'd have to look up the rule to be exact, but if I recall we replaced the Cav stands with Infantry stands when they dismounted.
PostPosted: Wed Sep 01, 2004 6:57 am
Quote (Legion 4 @ 01 2004 Sep.,05:30)
That's how it was done. Ahem...
To dismount, move the mounted stands as normal and then replace each stand in the detachment with a tactical stand or command stand, as appropriate. Once dismounted, stands cannot remount.
WD124 P.36
Both bike and RR stands could dismount.
PostPosted: Wed Sep 01, 2004 7:55 am
I kinda like the idea of just letting them act as infantry when in cover - like they have just hopped off their mounts for a bit.  Did that in E40k quite often, but it really should have cost extra points.
PostPosted: Wed Sep 01, 2004 2:41 pm
Looks like Mojarn pitching for that "keeper of lore" position.... :;):
PostPosted: Wed Sep 01, 2004 3:09 pm
Thanks Mojarn, it appears my memory has not (yet) faded completely. :;):
PostPosted: Wed Sep 01, 2004 10:44 pm
Quote (Mojarn Piett @ 31 2004 Aug.,22:57)
WD124 P.36
Thank You!
dafrca
