Post new topic Reply to topic  [ 1449 posts ]  Go to page Previous  1 ... 25, 26, 27, 28, 29, 30, 31 ... 97  Next
Armyforge Update (Online EA Force Creator)
 Post subject: Re: Armyforge Update (Online EA Force Creator)
PostPosted: Wed Feb 27, 2013 11:02 pm
Afaik there are rumblings of change for latd, but separate from the chaos marines....
PostPosted: Wed Feb 27, 2013 11:04 pm
Oh and also MoK, check your PM....
PostPosted: Sun Apr 07, 2013 4:54 pm
I'd like to volunteer to do the EUK chaos and dark eldar lists if they're not being done....
PostPosted: Mon Apr 08, 2013 2:18 am
Contact Mephiston, he is coordinator - not heard much from him lately though...
An online epic force creator:
Armyforge
PostPosted: Mon Apr 08, 2013 2:26 am
Hey Adam,
Any chance the Red Corsairs could get an update mate, all the aircraft are wrong.
Aaron
PostPosted: Fri Apr 12, 2013 3:20 pm
EUK updated guard lists due to be uploaded this weekend, EUK Dark Eldar and Chaos lists have been updated and submitted for checking :)
PostPosted: Sat Apr 13, 2013 3:56 am
EpicUK IG & Nids updated - thanks Kyussinchains & Mephiston.
NetEA Squats updated - thanks Borka.
@CAL001 i don't have time for list updates nowadays, but you're welcome to have a crack yourself...
Armyforge
PostPosted: Sat Apr 13, 2013 9:42 am
Woot! Squat list updated just in time for games tomorrow - thanks to all involved for the fine work :)
May your tankard never be dry and the Dice Gods look favourably upon your endeavours!
PostPosted: Sat Apr 13, 2013 7:27 pm
well this is embarassing, error in the EUK steel legion list, mechanised infantry should be 400 pts, they're currently listed as 500.... is this something you can fix easily adam or will I need to re-jig it?
PostPosted: Sat Apr 13, 2013 9:45 pm
I re-jigged it.
Armyforge
PostPosted: Fri Apr 19, 2013 10:37 am
Thank you so much for your effort, guys!
ArmyForge is the best force creator on the net imho!
PostPosted: Thu May 02, 2013 10:09 pm
I've just found a slight issue:
I use the Saranse Expanse list, http://traitor-legion.appspot.com/choos ... sade_NETEA.
Currently, in an Imperial Crusade Tank Company, you can convert all of the Leman Russ' to Vanquishers for no cost.
On the PDF (NetEA-ArmyCompendiumS1.2) it says 'One Leman Russ may be upgraded to a Leman Russ Vanquisher +25 points'.
Sadly I'm guessing the PDF is accurate.
PostPosted: Thu May 02, 2013 11:14 pm
Armyforge is subordinate to the PDFs so rely on them (assuming you have the correct version of the PDF).
If you want to fix the Saranes list, then PM me...
Armyforge
PostPosted: Fri May 03, 2013 12:32 am
I will double check things from now on but I've become very lazy as Armyforge does all the work.
I've PMed you about fixing the list.
The PDF I used was: 2010 - NetEA-ArmyCompendiumS1.2 - Imperial Guard
Is that current?
PostPosted: Fri May 03, 2013 3:59 am
Latest lists are here -> http://www.net-armageddon.org/
Armyforge
