Post new topic Reply to topic  [ 93 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7  Next
Nid E-A Playtest: 1,000pt vs. Eldar!
 Post subject: Nid E-A Playtest: 1,000pt vs. Eldar!
PostPosted: Tue Jan 06, 2004 11:51 pm
Fifth horseman, send what you got to:
primarch@caribe.net
Thanks!
PostPosted: Wed Jan 07, 2004 4:50 am
Quote (nealhunt @ 07 2004 Jan.,05:44)
For example, the first chapter specific army in your IA is the Dark Angels. ?By the end of the list, you have six special rules:
Actually neal, I found TFH's attempts to add the different flavours to the Chapters very interesting and while I wont be using many of them (if at all) I thought they did what he wanted- represented the armies in the light of the background they represent.
You are quite right about GT games, but then, I hardly ever play them and vastly prefer scenarios and home grown specific engagements anyday.
To each their own, as always!  :)
Tas
PostPosted: Wed Jan 07, 2004 7:52 am
Quote (Tas @ 06 2004 Jan.,19:50)
My main issue is that many of the rules that he adds are rather complicated and also go against a stated aim of EpicA, trying to avoid the Codex-creep of 40K with new special abilities for each army that comes out.
You are right, to each his own, but I really do think that TFH's army lists would be better served with some substantive editing and a more focused approach. He certainly has the energy and the imagination (and frankly more power to him for just that alone), he just needs to try to be less enthusiastic and not try to cram so many rules into the lists.
A hint of the flavour is often better than too much.
He should continue to produce and post lists...but I really do think that "less is more" is an adage he should take to heart
PostPosted: Wed Jan 07, 2004 12:49 pm
1.  I respectfully disagree.  For example, in the playtest forum I recently questioned the Deathwing terminators in your IA list.  You made 2 points in response - that the background reads that way and that it modeled the 40K rules(highly debatable), but your response was primarily fluff-driven.
Duh. And Boris does most of special rules stuff in his lists based on the fluff...
Anyway, there is a difference in saying that most of the list is modelled around the fluff ans that most of the list is fluff, isn't it?
2.  You have continued to add special rules in large quantity.  In addition, you have added multiple units that are so similar to existing units that the differences will have no difference in play, adding unnecessary complexity.
For example, the first chapter specific army in your IA is the Dark Angels.  By the end of the list, you have six special rules.
Not at all. The multiple units that are similar to existing ones were added not for without a reason, as there are certain differences that make them distinct. This is one of the elements of the army specifics.
And these disting changes make the difference when playing, believe me.
Remember also, that the new special abilities and rules do not apply all at once.
Special Weapon abililty applies to some of the flame and melta weapons, and is something that would be v. good addition to the basic EA rulebook - simpler to say that Multi-Melta is a MW 5+, Special Weapon, then that it is a MW 5+ and Small Arms (MW), isn't it?
Technician is also an ability, used only by the Techmarines. I heard ppl moaning on the playtest board about what abilites the Techmarines should have and this is really simple in comparison to some ideas there.
There are also significant problems with new units and army list organization.  20% differences in WE support costs, for instance, causes a very big change in play balance.  Another example is the fact that the Iron Hands chapter could potentially have a half dozen Supreme Commanders in the form of a Venerable dreadnoughts scattered through the army.
I thought I have removed most of the WE cost change stuff... damn my failing memory.
Anyway, it is to discourage players from taking some WE's when not neccesary.
And you missed one annotation, that is placed in most lists. It reads: "No matter how clever your logic, you can have only one Supreme Commander in your army, EVER."
Only a single Ven Dread per army can be upgraded to a Supreme Commander.
Also remember, that altought there are some special rules, many of them are stuff considering deployment and army selection.
Also, what is the second rule in the Ultramarines list? I remember only including the one about Seditio Opprimere. And it is simple, as before the game you just roll to check if you get normal Battle Barge or the Seditio. What's difficult about it?
And to PG: What I'm doing is to try to put the flavor of the armies where it belongs, and streamline the rules as much as possible. Don't you remember what my first army list was like? Compare it to the EIA. See the improvement?
I don't have this much energy... when I finished adding all the new to EIA I was exhausted wreck of my former self. On other hand, sometimes I work like a maniac...
And I always need to do something...
The Fifth Horseman.
Quality over quantity.
PostPosted: Wed Jan 07, 2004 2:13 pm
First of all I just want to say that I don't want to get into a heated debate as english is not my first language and misunderstandings are bound to happen.
However I still feel rather strongly that Neal and PGs comments were unnescesarily rude. There were absolutely no reason to point out that you particularily disliked TFH's lists -sure you elaborated later on why you didn't like it but this whole issue could have been avoided if you'd simply said which lists you found to be the best and left it at that.
One of the things i really like about this forum is the friendly athmosphere where people give each other constructive feedback on various projects. To simply say that a list (or a paintjob or whatever), which someone has put a lot of effort into is no good, I find extremely rude. At the very least you could have given some constructive critisism. Pointing out what you didn't like about the lists AND THEN given specific examples on different solutions.
As previously noted this is by no means meant to start a flame war -what paople have said is too late to undo now - but for future record I felt that it was improtant to say this. Try to be considerate when commenting on somebody else's work and not just dismiss it as no good.
Cheers!
PostPosted: Wed Jan 07, 2004 2:52 pm
Yeah, we are all buds here, lets keep it this way :). Lets be more like the Waltons (but with better hair, clothing and night life) and less like the Osbournes :S.
Although - Ozzy does some great music...
Tom Webb
PostPosted: Wed Jan 07, 2004 4:53 pm
I share your point of view, Warmaster Nice.
Maybe PG is jealous that I'm doing a Blood Angels list that might be a viable alternative to his one?
The Fifth Horseman.
PostPosted: Wed Jan 07, 2004 4:59 pm
Quote (the_fifth_horseman @ 07 2004 Jan.,15:53)
As do I, it was well put. But please - lets be nice here :D.... go to your happy place people (for me that would probably be the pub)!
Tom Webb
PostPosted: Wed Jan 07, 2004 5:56 pm
Quote (the_fifth_horseman @ 07 2004 Jan.,07:53)
Always interested in comments on my BA army list.
There is already a rather long topic about it on the Epic Forum
http://forums.specialist-games.com/epic40k....C_ID=34
and I'd be more than happy to read any comments that you have about it. There have already been some very good responses and I've got some good ideas adn fixes to the list already so if you have some comments please do post them.
PostPosted: Wed Jan 07, 2004 6:01 pm
Quote (Warmaster Nice @ 07 2004 Jan.,05:13)
Perhaps you are reading some intent into what I've posted here but I'm really just stating an opinion.  Not trying to be rude nor do I really think that what I (or Neal for that matter) have posted is untoward or meant in any way other than to extend an opinion.
YMMV of course but I really do think you are reading too much ill-will into these posts.
PostPosted: Wed Jan 07, 2004 6:30 pm
Now, now boys. While not my specific forum to moderate, I'll save everyone some grief and ask everyone to calm down.
I will say I found it odd that some strong comments about TFH's lists were made, since all I asked were there any Necron lists and the URL to them.
The arguments of less detail or more detail are the same age old ones that were the crux of the "epic 40k versus Space marine" flame wars of old (I should know, I was in a few of them... :;): ) and have no right or wrong answer. Its a matter of taste, thats all. No need to get angry over this point. Some like less, other more detail, special rules, etc. in their rules. After almost 15 years dealing with epic in all its forms I have learned that one group will NOT convince the other to its view. So lets be more friendly on this point and leave it at that.
I'm using said lists merely because I dont know enough about necron's to make a list for net epic and such lists for Epic A (fan based or not) will help me know what makes up a Necron army.
The rules, mechanics and all the rest will or course be made up be the net epic list and myself as usual.
While we all disagree what the "best" rules are we all do love playing epic.
Let us remember what we have in common.  :)
PostPosted: Wed Jan 07, 2004 6:57 pm
My apologies if my posts sounded aggressive. As I stated (a couple times), it was not my intention to start any sort of conflict. I simply dislike TFH's lists and stated my reasons.  I know from his writing in other venues that he recognizes not everyone will like his lists.  Apparently, however, I was too blunt and it came across as rude.
TFH: ?Perhaps I could have phrased my criticism better. When I said "all fluff," I meant that I felt the rules were too background-oriented, not that the lists consisted primarily of background text. In answer to your question, the other UM rule was something about deployment. I don't remember the name off hand.
Also, you may very well have removed the change in WE prices. There are two IA lists out there on the Yahoo groups and they differ considerably.
PostPosted: Wed Jan 07, 2004 6:59 pm
I don't believe anybody had any ill intentions with their posts. Of course everybody is entitled to express their opinion but one should allways try to be as considerate as possible when commenting somebody elses work. It is all to easy to come across much more harsh than originally intended.
PostPosted: Wed Jan 07, 2004 7:10 pm
Gentlemen,
There has definitely been some animated language here, but everything seems to be in hand so, We "moderator sorts," will let everything go for the moment. If things get a little more heated, I'll (or we'll - chatting with the other moderators at the moment) close down the thread for a week or so and reopen it after things have cooled down. So far, so good... :)
Best regards to all and Shalom,
Maksim-Smelchak, Uber-moderator.
6mm Sci-fi:
My Personal Blog:
PostPosted: Wed Jan 07, 2004 8:39 pm
The "Best" rules are the ones you and your crew agree to use to play Epic or any other game ... and I've been "Epicing" since '90 !   :;):
