Post new topic Reply to topic  [ 79 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Space Marine Fixes Thoughts/Ideas
 Post subject: Space Marine Fixes Thoughts/Ideas
PostPosted: Mon Aug 01, 2005 12:54 pm
And modern 40K fluff permits Drop-Dredds..... :p
Back from oblivion (again)?
PostPosted: Mon Aug 01, 2005 1:13 pm
Quote (Jaldon @ 31 2005 July,20:25)
(1) In General Too Weak in Assaults
(2) Vindicator Not Worth It
(A) Increase it's speed to 25cm
© Give Demolisher Cannon Ignore Cover
(3) Too Weak Against WE
(B) Live with it every army should have weaknesses
Jaldon :oo
Are Marines weak in assault?
Whenever my regular opponent gets an engagment going I really suffer, but if I do it on my terms then he suffers.
Vindicator - Increase in speed almost universally agreed & ignore cover, no problems from me there.
Can't deal with WE? Well there are termies, and you can have your own WEs so whats the problem.
Now for the disclaimer. I don't play Marines. I find them too difficult to play with, but I am prepared to look for solutions and try and test new ideas.
A problem that has been raised is that a single shot can cripple the movement of a formation by destroying one of its transports. Now Marines can still double and March which can cover a lot of ground.
I originally had a possible solution of increasing the save for Rhinos and Razorbacks, but discussing this with Nick (Mekboy) Simmerson, Speed Freak Champion and general brilliant player he came up with a better solution.
Similar to IG and their Commissars, Marines have Techmarines. Before a battle the Marine player rolls a D3+1 for techmarines (assuming upto 3000pts). He does not have to allocate these, but must have a suitable marking system to show that he has them.
Then during the game these techmarines may be used to allow the player to re-roll a failed armour save on a vehicle. Note a save can only be re-rolled once and if the vehicle has already used a re-roll for say Reinforced Armour, he can't re-roll a re-roll. However if the same vehicle is hit by a MW then the first save is lost, the second save can be taken and if this is failed then a techmarine may be used. Of course TK weapons would not be affected by this rule.
Well I'm open for comments and if there is a bit that doesn't make sense then I'll try to clarify it.
Tim
PostPosted: Mon Aug 01, 2005 1:28 pm
I like the Tech-Marine: After all, it worked well in SM2!
Would that also herald the return of the Medic with personnel saves?
When I pushed this in the initial EA playest forum (lets see, thats 3 offiial forums ago now..) I was told it was too complex?  has this officla attitud echanged to allow more character diversity?
Tas
PostPosted: Mon Aug 01, 2005 3:48 pm
I, too, like the ideas of Tech-Marines and Medics.
As for the Vindy, it should have the Ignore Cover ability.
Dreads- let them be able to be deployed by drop pod. Also, am I the only one that would like to see them as seperate formations, instead of just upgrades?
PostPosted: Mon Aug 01, 2005 4:02 pm
I think the marines are pretty close to being okay and only need some minor tweaks.  Here are the items I have advocated to the Rules Committee:
Vindicator - up the speed to 25cm
All armor formations (except Whirlwinds) - drop 25 points to 275 points/375 for LRs
TSKNF changes:
Leaders remove 2 BMs
Drop the outnumber mod by 1, i.e. outnumbered is +0, outnumbered more than double is -1.
PostPosted: Tue Aug 02, 2005 12:53 am
It has been a while since I jumped in on this but...
I am still of the mind that Tech-marines and medics don't need to be complicated to be in the game. The "Leadership" ability alone works well. ... sorry but I don't want to hear the "They aren't leaders!" argument. It is the effect not what you call it. The point is that you get a reasonable solution with out adding any new rules (except maybe expanding their Invulnerable Save to include some number of units in the detachment.)
In any fluff I can remember SM's could care less about beinging outnumbered, period.
end of rant :cool:
Wolf1
PostPosted: Tue Aug 02, 2005 1:28 am
Good point.  Fluss-wise, if Marines aren't outnumbered, then the Emperors resources are being waisted.
Note to self:  add clever signature
PostPosted: Tue Aug 02, 2005 6:26 am
Quote Warmaster Nice
Dreadnoughts.
There's been some suggestions about letting them use Drop Pods for increased mobility.
End Quote
*Jaldon looks left then right* pssssst Dreadnoughts can use drop pods, and Thunderhawks, and Landing Craft already.
Jaldon :oo
PostPosted: Tue Aug 02, 2005 8:21 am
On the WPS Epic Rules Committee, yes I know I should go outside once in a while, it has been suggested to bring in a whole command stand.
This would use the techmarine rule above, a similar version for the apothic##$$## Medic and also a Standard Bearer to allow for limited reduction of BM.
The idea is to reduce the Supr Com to +75pts and havethis additional up-grade at + a further 50pts.
I agree that ome of the existing rules could be used further. ie Inv Sv, but is a bit of a throw away save and not a bonus to be used when really needed.
Tim
PostPosted: Tue Aug 02, 2005 12:44 pm
I quite like the techmarine idea but as an alternative, how about just give Rhino's and razorbacks the chance to re-roll their armour save? (but not anything else based on a rhino chassis) Without the limitation of D3 +1 which the techmarines would give.
Fluff wise it could be justified by the fact that Rhino's are incredibly easy to repair
PostPosted: Tue Aug 02, 2005 1:15 pm
Quote (The_Ape @ 02 2005 Aug.,12:44)
That is basically just giving them the reinforced armour ability... which I don't think they deserve.
An invulnerable save maybe... to represent the ease of repair etc of rhinos (not razorbacks which are already good value in epic, and also don't have the easy repair ability in 40k).
PostPosted: Tue Aug 02, 2005 2:11 pm
(Fix) Change outnumber result to the following
(A) If outnumbered by 2 to 1, or more then enemy gets +1
(B) If Even or just outnumbered enemy gets +0
? If Marines outnumber enemy they get +2
Sounds groovy
(B) Give it FF+1 attacks
? Give Demolisher Cannon Ignore Cover
OR
(D) Decrease it's Detachment cost to 200pts, and per unit cost to 50pts
Decrease cost - it has to preserve the link to 40k for the studio to accept it.
(A) Make Hunter MW4+TKD3 AA4+ :p
Live with it
Other things to consider:
Armour is too expensive - especially the Land Raiders. I never field them any more :S.
Tom Webb
PostPosted: Tue Aug 02, 2005 2:30 pm
Quote (Markconz @ 02 2005 Aug.,13:15)
Well, id personally be happy with just a better armour save. You are right, they dont deserve the reinforced armour rule, but on the same note, i feel the invulnerable save is not much better.
PostPosted: Tue Aug 02, 2005 2:55 pm
I am quite happy with rhinos as they are TBH.
Tom Webb
PostPosted: Tue Aug 02, 2005 3:09 pm
Well I agree, to upgrade the Vindy and Hunter. And yes, we let Dreads use  Drop Pods, the new big ones vs. the small old versions which, carry SMs (Assault Pods), Deathwind Rockets and a Heavy Support Weapon.  We may even give the Assault Pod a weapon as in SM1.  We also still use M/Mortars and T/Guns, as well as  Tarantulas and Rapiers with our SMs, as in SM1.  And all our Epic Forces still use the SM1 Off Board Support system.  So there is no such thing as too much firepower !     :;):
Users browsing this forum: No registered users and 121 guests
