Post new topic Reply to topic  [ 30 posts ]  Go to page Previous  1, 2
What formations do you guys use?
 Post subject: What formations do you guys use?
PostPosted: Sun Feb 15, 2004 8:04 pm
Hmmm, after some thought, I agree that the rules require no modification.  After all, how many times is this situation going to occur in a game?  If the opposing force goes into overwatch after watching you march up, then they should pay the price for guessing wrong.  Although, if I had an assault biased formation march up to one of mine, I would probably think about doing the same thing.  And how many pro-assault formations can really shoot good at range?
my 2cents,
iblisdrax
PostPosted: Sun Feb 15, 2004 9:58 pm
Quote (iblisdrax @ 16 2004 Feb.,04:04)
After all, how many times is this situation going to occur in a game? ?
Often in a good game!- but then that is part of the Command Decision Process.  As you say there are a myriad of factors- guess the wrong one and your men will suffer for it.
There are lots of tactical options here, and OW is only one of the possible solutions....
PS Greetings Agent Brown!- Hope you like it here as much as we do! :)
Tas
PostPosted: Mon Feb 16, 2004 12:50 am
Good call Agent Brown ... the more guys play E:A and tell us about it, the more we all can learn ! :cool:
PostPosted: Mon Feb 16, 2004 1:00 am
Goes to show sometimes a rule may bug "you" but everyone else is okay with it. Gaming quirks is all.
PostPosted: Mon Feb 16, 2004 12:36 pm
Interesting. Thanks guys (in particular Tas), you have convinced me.
PostPosted: Mon Feb 16, 2004 5:53 pm
Isn't the point that if you have an enemy formation in front of you, and you want to shoot it, you should choose sustained fire yourself?
Choosing overwatch orders should not be a solution for the problem that you can't make your mind up when it's your turn to move -  "Do I shoot at these Orks now, or hope that a more juicy target presents itself later?" being the kind of indecision that makes a recipe for miltary disaster, as it confuses your own troops on the ground.
It may well be that JJ didn't *want* people hedging their bets in this way.  "Shoot now, or risk losing the chance altogether" being the lesson.
Perhaps we're in danger of getting confused because of the number of games in the past where Overwatch and Sustained Fire have sought to achieve the same ends?  In E:A, Sustained Fire is all about having your lads pour as much fire into the enemy over there *right now*; whereas Overwatch has them ignoring that lot over there, and instead pointing their guns somewhere else in the *hope* of getting the drop on some other guys you think might be moving in the next 15 minutes.
PostPosted: Mon Feb 16, 2004 6:02 pm
As the commander on the ground, you have to make that decision. That is one reason why I like Epic ... it's more like chess, where say 40K is more like checkers !  Both good games in the own right, but I won't be playing checkers anytime soon !  :laugh:
PostPosted: Mon Feb 16, 2004 8:37 pm
Gotta agree with whats been said. If the target is alreaday in range and LOS don't go on overwatch, go on sustained fire (or whatever action you prefer to attack the target), but not overwatch.
Overwatch is meant to sit and wait to shoot at targets that entre your range and LOS, that were not in range and LOS at the time you choose the overwatch action. eg there are some nasty skimmers on the other side of a ridge ready to do pop-up attacks on your formation. Then go onto overwatch, forcing your opponenet to either accept the OW fire from your units or not attack the formation on OW.
PostPosted: Mon Feb 16, 2004 11:17 pm
This is the heart of the matter, and why wargaming is a challenge (and fun!). IMHO a good set rules emphasises this and all else supports the resolution of the decision.
Back OT though, another option is to pound the target with something else and see which way he jumps- you may seriously diminish the threat posed (through casualties or BMs) and open up other options.
As any grunt will tell you- when in doubt call in fire support!
Tas
PostPosted: Mon Feb 16, 2004 11:52 pm
For me "overwatch" or reaction fire is a mechanism to eliminate movement with "impunity". In game systems where the action sequence is "integrated" you run the risk of have very unrealistic movement since the other player can't do anything to restrict you.
Overwatch or its equivalent makes movement "risky" its not a given, it has danger. Thats were the tactics come in and makes it interesting. Overwatch fire can impose different penalties on the target. Casualties is one, but there are others like stopping movement or causing morale checks (some of these more effective than just casualties).
So it depends what your particular philosophy is regarding this mechanic. Pick what you want it to do and modify accordingly.
PostPosted: Tue Feb 17, 2004 5:25 am
A good set of rules will allow  Grunts to "call-in" supporting fires on a target out of range of his element's organic weapons.
PostPosted: Sun Aug 29, 2004 4:14 pm
Location: University of Essex, Colchester, UK (soon to be Brighton, Sussex, UK)
Hello all,
Having been lurking over the E:A rulebook a little bit and trying to decide on my own starting army I was curious to know what you guys use as your typical force or if you have sucha thing at al (instead of changing your army list regularly).
This causes me to ask people to post an army list that they regularly use (in sketchy format, no need for exact details if you don't want) or if you don't regularly use the same list or variants of it, why don't you? Is because your opponents change a lot and you adapt to them? because you face a specific treat in some cases/alwaysand have found that combo of units to be the best solution? ....
Thx for your time in advance :)
Health and sixes,
Xavi
Commanding legions forward while sitting in a nice armchair.
PostPosted: Sun Aug 29, 2004 4:49 pm
We still use SM1 templates for the most part.  Usually Bn size, with attachments.  The templates are very flexible.  So you can modify them based on mission very easily.  We normally have Rgt size units, and can easily pick a Bn TF or two from those.  Or we utilize "coalition warfare" and say ... pick an SM Bn supported by an IG Co. Tm, for example.  However the rules prevent "cherry picking" ! :;):
PostPosted: Sun Aug 29, 2004 6:32 pm
For my normal army, I use at least one Mech Infantry and one Tank Company. My support and upgrades change to fit the army I am playing if I know before hand.
Overall I love massed infantry and tanks so the final point value sometimes adds to the number of companies I bring.
dafrca
              - Cities of Death, page 59
PostPosted: Sun Aug 29, 2004 11:06 pm
I second Dafrca, at least one Mech Inf Co and a tank co, and I usually field a battery or two of artillery.  I add an inf co or a tank co depending on point total and opponent, if known.
my 2cents,
iblisdrax
