Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Hellbore
 Post subject: Hellbore
PostPosted: Tue Feb 24, 2004 2:45 am
IN net epic the termite has bolters, the mole more bolters and a lascannon. The hellbore has even more bolters and a couple of lascannons, but its main weapon is that when it surfaces a large area gets turned to slag because of a drill mounted melta weapon. This helps it surface as well as cleaning the beachead.
PostPosted: Tue Feb 24, 2004 2:57 am
Quote (primarch @ 24 2004 Feb.,10:45)
Neat...and nasty!
Without me running off to look it up, could you describe how this is affected?  By Blast template perhaps?
Tas
PostPosted: Tue Feb 24, 2004 3:14 am
Yes, we use the extra large mega-gargant 12cm barrage template to figure out the blast radius. Very big and very deadly.
PostPosted: Tue Feb 24, 2004 3:39 am
I'm looking at the SM1 data sheet that came with CT : ?Assault Pod - Hvy Plasma Gun, Support Pod - Plasma Cannon, Deathwind - Deathwind Missile Launcher (special rule - use 12cm template, pod in middle, everything under template, even partially, must make SAV throw). ?Termite - Las-cannon (x2) & Hvy Bolter, Mole - Multi-Launcher (x2) & Hvy Bolter (x2). ? Hellbore (from a W/D article), Multi-Melta (Lx4), (Rx4), Hvy Bolters (Lx4), (Rx4) plus the slag effect as you described. ?Using a 12cm template, all infantry under template is destroyed, all others suffer 1D3 critical hits. ?All surviving units are moved to edge of template. ?Units within 12cm of template edge must make SAV throw. Buildings within 18cm of center take D6 critical hits. ? That's what it says in the SM1 rules. ?And we generally use those.
PostPosted: Wed Feb 25, 2004 12:30 am
Cool!  Thanks guys!
:D  :D  :D
my 2cents,
iblisdrax
PostPosted: Wed Feb 25, 2004 1:45 am
In SM1 the CI and the tunnelers had very powerfl weaponry. They were watered down a bit in later versions.
PostPosted: Wed Feb 25, 2004 2:05 am
So what do you think the points should be for a Hellbore - what about 400 points (given that it has no shields).  I mean one with the abilities described above.  And how about 100 for a mole (or 300 for a 3mole formation)?  and 30 for a Termite?
Comments?
my 2cents,
iblisdrax
PostPosted: Wed Feb 25, 2004 6:43 am
Reviewed my TO&Es - Hellbore 500, Mole 150, 3 Termites 250.
Users browsing this forum: No registered users and 128 guests
