Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
To base or not to base...
 Post subject: Re: To base or not to base...
PostPosted: Fri Jul 10, 2015 6:56 am
the other thing with basing is that it can help remove any ambiguity as to line of sight/LoS blocking etc.... 'your shadowswords can't see the gargant, the buildings are in the way!' 'they can see the tip of his gun poking out, I'll take the hull down but they can definitely see part of it...'
if everything is based you can say in the 5mm warm up that you're playing base to base for LoS then that removes the ambiguity quite a lot, and also helps to standardise some of the many different shaped and sized models in the game (GW vs FW thunderhawks spring to mind!)
PostPosted: Fri Jul 10, 2015 9:00 am
I agree Jimmy, though as Markonz says, DWWFY.
PostPosted: Sun Jul 12, 2015 6:43 pm
Excellent feedback guys. Along a similar note what glues do you use for the bases. I've always heard wood glue is a good option. And does anyone have an opinion on sealers? I have heard going gloss first followed by a dull coat is one way to do it. Any recommendations on brand names? Thanks as always!
PostPosted: Mon Jul 13, 2015 2:29 am
I use Loctite. Drys clear and bonds in a few seconds. Super strong so I never need to seal it
PostPosted: Mon Jul 13, 2015 2:53 am
Loctite's the best! I use it for bonding metals and plastics but hadn't considered it for basing due to it being relatively expensive. Will have to reconsider potentially.
PostPosted: Mon Jul 13, 2015 7:27 am
I think that basing of all units should be mandatory in tournaments. For the same reasons that KIC stated.
PostPosted: Tue Aug 11, 2015 4:31 pm
I'm a big fan of Litko's bases, like this one:
http://www.litko.net/products/Square-Mi ... coi9_lVhBc
For 6mm, I recommend getting the 0.8mm plywood. I've found that's the best way to go for these little guys. And it's surprisingly sturdy, particularly if you've added some basing medium like Vallejo Sandy Paste, which strengthens the base.
PostPosted: Thu Aug 13, 2015 10:34 am
I never used to be a fan of mounting tanks, etc. on bases, but I think I'm going to try it as I'm coming around to the idea.
Mounting small tanks such as rhinos on UK 2p pieces looks pretty good to me. I think it makes them a bit more sturdy and less likely to get accidentally knocked out of position. Dreadnoughts could go on 1p pieces, but can't remember off the top of my head if a 1p piece is within legal size limits for basing.
Users browsing this forum: No registered users and 93 guests
