Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
If one was to start Eldar...
 Post subject: Re: If one was to start Eldar...
PostPosted: Thu Apr 23, 2015 2:16 am
Around the world, I guess the NetEAlist *might* be played more. In the UK, it is possible that the E-UK lists are more used, not least because of the UK tournament scene.
The lists are similar but have some significant differences around the SoV and Fire Prism from the 2008 revision. Other changes to the Cobra and Scorpion stats, and Phoenix Bomber costs are more recent attempts to make them more appropriate and playable.
Both variants are viable and generally accepted. In the end the choice is up to you . . .
PostPosted: Thu Apr 23, 2015 9:08 am
Bellerophon wrote:
Played a game with the E-Uk list and it was an interesting game and the list was quite solid.
That being said my group want to use Net Epic for lists.
Question is which system is played more ( got the impression that the lists were quite similar, until I saw the differences with Ulthewe).
Do you mean NetEA (different lists for Epic Armageddon) or Net Epic (different and incompatible edition of Epic)?
If you mean NetEA, outside of a tournament there isn't really an issue with using lists from both sources.
The Wargaming Trader
PostPosted: Thu Apr 23, 2015 9:24 am
In my group here in Spain, we used to play with NetEA, but we have finally switched to Epic UK lists. Simpler, more sensible and tested.
PostPosted: Thu Apr 23, 2015 9:43 am
I'd advise you to use EpicUK lists for the most part, and NetEA for any armies that EpicUK doesn't cover like Knights, Squats and so on.
