Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
special abilities and off board formations
 Post subject: Re: special abilities and off board formations
PostPosted: Thu Jun 05, 2014 1:37 am
<offtopic mode="activate">
Keep this up and we'll need to give you your own area called, "Dave's Ponderings" ;D
PostPosted: Tue Jun 17, 2014 9:16 am
How about the Eldar Avatar? Is there any reason he can't be summoned by a guardian formation in the webway and exiting the portal with the formation afterwards?
PostPosted: Tue Jun 17, 2014 10:51 am
No, you cannot do this either; you hit the same issue as all the other cases. Many examples require the two formations to be within a specified distance, "within 15 cms of the Farseer" in this case. Where the Farseer is in the webway, you cannot 'measure' to his exact location - and before you ask, NO, you cannot measure to a 'gate either (the webway is effectively in a different dimension to the battlefield).
To re-itterate, any "ability" that is off-table cannot be used to influence something that is on the battlefield. Indeed in principle, there is *no* interaction between on-table and off-table formations.
The ONLY exception to this is the Supreme Commander - once he is actually on the battlefield, you may use his re-roll for an off-table formation that failed its activation test or it's rally test.
Note that here you are actually asking two questions, both of which are not permitted
  • At the start of the turn, the Farseer in the webway may not be used to summon the Avatar onto the battlefield - the Avatar cannot be placed within 15 cm of the Farseer.
  • Once he has been summoned, the Avatar cannot use "commander" to control formations in the webway - the formation in the webway must have a "unit within 5cm of a unit from the commander's formation", and you still cannot measure into the webway. ;)
Users browsing this forum: No registered users and 91 guests
