Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
E:A Black Legion Army List
 Post subject: E:A Black Legion Army List
PostPosted: Fri Jun 20, 2003 4:50 pm
Well, like I said, much of E-A is still "under construction", it appears, regardless of the fact that they said the rule book was headed to the printer (?).
The dicussion on the FA topic showed Jervis was still making changes (?). ?
So, I imagine the final copy will come with an errata sheet or pamphlet (?). ?
I'm glad we use our own "hybrid" rules and only adding a few things from E-A like modified Flak rules and maybe even the ranged combat system?
My buddy is going to Games Day US this weekend, (besides getting me some F/W Epic Night Spinners and possibly some other new Epic F/W (?) ), he is going see if he can get any new intell on E-A. ?
Anything worth noting, I'll let you all know... ?:D
PostPosted: Fri Jun 20, 2003 5:03 pm
It's not at the printers. ?
It's with the editors getting print-ready, and doing the (supposedly) final draft. ?
Printing isn't supposed to start until September, IIRC.
PostPosted: Fri Jun 20, 2003 5:14 pm
Well,
That's good, but that is also why I put a (?). Because I've said this many times before, after 12+ years of "Epic'ing", I'm a "cold zero" realist - until I have something in my hands, it's in the realm of Nessie, Big Foot, Roswell etc. ?
Again, G/W is "artist driven" so style always - I say again - Always - supersedes function and form. ?
You'd think G/W was run by females!!! :laugh: ?
Albeit quite rich females!!! :laugh:
PostPosted: Fri Jun 20, 2003 5:29 pm
Neal,
Originally I wasn;'t going to respond, not out of being offended (Dafrca and Neal are both gentlemen of the highest caliber), but because I'm not sure how much this topic could add to the forum other than adding my gripes and dissatisfaction about E-A.
On the other hand, maybe someone will prove me wrong, which I'm all for! :D
Maksim: ?I think some of the points you make don't apply to the latest stuff.
OK, Point taken. I'll stand corrected!
- Stompas
They are exactly what you want - tough fire support. ?They have 2 big gunz and Reinforced Armor, with optional CC. ?AFAIK, they have always been 50 points.
I think what I mentioned before is that while Stompas are still OK, they were once MUCH BETTER. They were a real threat to enemy armor, even Land Raiders. Now, in a Stompa vs. LR combat, I'd put money on the LR unless the Stompa can get close (not very likely unless the terrain favors the Stompa).
Stompas are tough fire support, but with only two Big Gunz, they are woefully under armed if they're to oppose enemy armor. Two 5+ shots means roughly 1/3 of the time, it's hitting. Pretty pitiful and this is before negative modifiers.
- Ork Warlord - It looks like he was eliminated.
The Warlord upgrade in most formations was scrapped in favor of much-improved nobz. The Warboss/Big Boss upgrade that comes with an ork force is still there.
He is a character and a supreme commander and the point about Nobz is a good one. Shedding BMs is great. I concede on this point.
- New limits on Ork formation size x2 or x3 also appear to be in place.
There is no limit on formation size, except for aircraft. ?They can buy the core formations at x2 or x3 size and cost because it's cheaper than buying each unit individually. ?Or did you mean something else?
Big Warbands and ?Uge Warbands: An Ork player can choose to double or triple the number of units in the Ork warband if he wishes. A warband with double the normal number of core units is called a Big Wareband and costs double the number of points. A warband with three times as many units as a normal warband is called a ?Uge Warband and costs three times the normal number of points.
I put a quote under your comments, Neal. I wouldn't be surprised if the part about Big Warbands and ?Uge Warbands is intended to be a limit set by Jervis. It definittely needs clarification.
- Orks lost most of their fluff rules.
They get "mob up" bonuses. ?They get wildly diverse formations. ?They get a Warboss. ?They get bonuses for charging into combat in a Waaagh-like fashion. ?That covers Orkiness pretty well, imho. ?What rules are you referring to?
These are the rules that they still have:
SPECIAL RULE: Power Of The Waaargh
SPECIAL RULE: Mob Rule
SPECIAL RULE: Ork Power Fields
The wildly diverse formations is good, but I refered to it as being a "broken concept" in my rules since some Ork players are using it that way.
Waaargh is better than it used to be (includes flyers now).
I miss the extra BM for the clangor of Ork fire. That was one of the rules that made tackling SMs much more manageable.
>> As soon as the Ork weaknesses become known, the limited nature of the Ork lists...
*boggle* Limited? The only limitations are Oddboyz, Supastompas, and the total points on WE/Aircraft. ?Outside of your personal preference for Supastompas, how does any of that limit strategic choices? Aside from a very non-Orky stand-and-deliver force, you can build anything you want.
Orks have a very limited number of units compared to SM or IG forces. This translates into a limited number of combinations, which is a liability in a list-based sytem. Look at 25mm 40k.
You can build just about anything you want, but they're all going to function just about the same: "Rush forward in a hoard and hope to overwhelm the enemy." This will work until IG and SM players wizen up and realize that Orks have one real strategy. Then SM and IG players should defeat Orks well over half of the time.
I find "Rush forward in a hoard and hope to overwhelm the enemy" to be a little limited and boring. It's one of the reasons I didn't care for the Orks in Epic-40k. They got slaughtered almost every game, even the ones that they won. I realize that the game is supposed to be balanced meaning that both sides will inflict and take casualties, but it always seemed well against the Orks even when the VPs indicated otherwise.
Having Orks that could "stand-and-deliver" was a welcome change. I was really pasting the SMs with tougher formations up until the Orks became so diminished from their first go.
Of course, it is perfectly Orky and GW-y to have lame and limited Orks. SMs are supposed to be the centerpiece of the game. That's why they have more choices, units, and most everything else (except the Red Wuns Dat Go Faster! Of course, Blood Angels do have supercharged vehciles so I guess SM Red Wunz DO go faster!). ?
>> By the latest edition of the E-A rules, they're back to being a hoard army.
I don't understand what you mean by "back to..a horde." ?They've always been "the green hordes." ?I understand you may not like it, but it certainly fits the background.
I mean by "hoard army" is that they're beginning to play exactly like they did in Epic-40k.
You're right, it certainly fits into the background. The Orks come in huge waves that are eventually whittled down so that the Imperial forces can win yet again!
- BFs with variable weapon loads
- The old 0-1 limits apply to Oddboyz upgrades and SupaStompas now.
BFs with variable weapon loads was the best thing since sliced bread. I'll miss them. SOB, SOB!
I agree you should be able to get more than one upgrade for the soopagunz (BFs and Big Gunz upgrade) and Painboyz (nobz upgrade). ?The Zapp gunz are too powerful. ?I doubt most opponents would object as long as you kept it reasonable. ?I would suggest you field your Pulsa Rokkits as Oddboyz Big Gunz so they have templates.
I'd rather have Pulsas than making Big Gunz with my single Oddboy upgrade into Pulsas. It's a good suggestion though! Thanks!
- Ork Bommas:
This would be nice, but I don't think its absence hurts the Orks. ?Ork airpower is wicked.
Try using Ork airpower to stop Imperial bombers. It's not easy.
Ork airpower works pretty well in the ground attack role. The Bommas were even better. They were also of the few new Ork units too! Of course, it has been hinted that they'll be back later (they're apparently suffering from not having a sculpt yet).
- Gunwagons, Battlewagons, Gun Trukks, etc. - All of the other things have been combined:
Were stats for Lungburstas, Gutrippas, ad infinitum, different enough to bother with, even in SM2? I never thought so, even for fluff.
Let's agree to diagree. I think that variety is the spice of life. It makes more combinations possible for a list-based system and keeps my opponenets guessing.
None of that was intended to be abrasive. ?You have my apologies if it came across as such.
No worries, mate! I'm good if you are too!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Jun 20, 2003 9:01 pm
>> [Stompas] were once MUCH BETTER... in a Stompa vs. LR combat, I'd put money on the LR unless the Stompa can get close... they are woefully under armed if they're to oppose enemy armor.
One-on-one, sure.  But Stompas are cheaper than any armor.
On a point-for-point, I'd actually lean towards the Stompas:  8 stompas vs. 4 LR.   Same range, more AT hits, walker, vastly better assault.  Equal BMs to break and Reinforced Armor.  LRs are faster and have better initiative.
Just out of curiosity, how were they better before?  I came in on V9.0.  Stompas now are undoubtedly better than they were back then.
>> I wouldn't be surprised if the part about Big Warbands and ‘Uge Warbands is intended to be a limit set by Jervis.
It's not.  That's just the most you can get at the cheap price.  I promise.
Okay.
Actually, the Orks have as many choices as the SM, in roughly the same areas.  IG have just a few more, but they are very restricted in force construction.  With their free-form formation construction, Orks have a definite advantage in variability.
Incidentally, the Kommandoes/Stormboyz formation will definitely be added, per Jervis.  His response was "Oops. It was supposed to be in there."
I disagree that it's all the same, but I don't think we will get anywhere on this topic. :)   I will point out that limitations on Ork tactics are due to their command, not their force construction.
Heh. :D  They were cool.  Like I said, it would be nice (and very orky) to have a formation that could lay down a barrage that was worth something.
Again, on a point-for-point, they are about even.  A Big Fighta-bommer formation (300 pts, 6 planes) intercepting a Marauder formation (250 pts) is going to kill an average of about 1.2 marauders while losing 2.2 FB.  That's about 60% Imperial losses versus 35% Ork losses.
No problem.   :cool:
PostPosted: Fri Jun 20, 2003 9:54 pm
Maksim-Smelchak,
Just to be clear. I do not disagree with all your points. In fact some are very valid and I would say the same thing.
What I disagree with is that somehow Orks are the only army to have found themselves being reduced in both "fluff" and power.
What I have seen so far is that there is a pattern to these things. First they decide Army X is dominating and too powerful. So they look to bring it in "balance." Often the formations that are seen as "out of balance" are those with special rules (fluff?) and thus they get changed. Often they go too far until Army X is losing all the time to Army Z. Repeat process until Army X, Y, Z are all reduced significantly in both power and specialty/oddities.
Dafrca
              - Cities of Death, page 59
PostPosted: Fri Jun 20, 2003 10:49 pm
Neil and Dafrca,
Just to be clear. I do not disagree with all your points. In fact some are very valid and I would say the same thing. - Dafrca
Thanks for the input. I value your comments.
If you'd like to point out all of my "very valid comments that you'd say the same things about" then, please do! My ego could certainly use the boost as I've been a little depressed lately.
What I disagree with is that somehow Orks are the only army to have found themselves being reduced in both "fluff" and power. - Dafrca
I don't think I said that the Orks were the only army that has lost out with rule set revisions. However, as a playtester who finally wanted to see Orks get a nice "face lift," I've felt the Ork losses the most.
>> You can build just about anything you want, but they're all going to function just about the same.
I disagree that it's all the same, but I don't think we will get anywhere on this topic. I will point out that limitations on Ork tactics are due to their command, not their force construction. - Neil
OK. I welcome you to come visit me and play a game to prove me wrong. I'll happily stand corrected, Neil! :)
All in all, I think E-A will be a fine game, but I really miss the great stuff that might never come to be now like the BFs with variable weapon loads and the Ork Bommas.
I'm really hoping to get a chance to play with all of you guys, Signius, Dafrca, Neil, Primarch, Tuffskull, and the rest of the gang.
Best regards to all and Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Jun 20, 2003 11:00 pm
Quote (MaksimSmelchak @ 20 2003 June,22:49)
I have a feeling that we may eventually see Ork Bommas...
FW are going to produce a 40K scale version and therefore eventually we may see an Epic version...
Though then again maybe not, as so far (correct me if I'm wrong) FW have not yet produced any Epic scale Ork models.
Jimbo
Felix's Gaming Pages
Felix's Gaming Pages Blog
Almost Always Right...
PostPosted: Fri Jun 20, 2003 11:14 pm
Jimbo,
I'm glad you posted. It always feels odd talking about Orks without you.
I sure hope we see the Bommas. I really LIKE them!
By the way, that reminds me that I need to get my Bomma photos on the hard drive so I can share them with all of you!
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Fri Jun 20, 2003 11:21 pm
Quote (MaksimSmelchak @ 20 2003 June,14:49)
Sure, I would be glad to...
I think you are on the money when you say the Stompa has been devalued. In the early rendition it was a quasi-titan. Now it is a poor Leman Russ wanna-be. It is no longer the threat it once was. Not that it is not worth having, it just does not fit the roll it once had.
The variable weapons loads for the Battle Fortress would have been a nice way of keeping the "each Ork vehicle is hand-made" feel to the formation/army.
I also must admit, despite it being silly, I did think the "clangor of Ork fire" rule added a simple advantage that gave flavor to the army.
Dafrca
PostPosted: Fri Jun 20, 2003 11:23 pm
Quote (MaksimSmelchak @ 20 2003 June,15:14)
Yes, you do need to get those up... :D
Dafrca
PostPosted: Sat Jun 21, 2003 12:18 am
Dafrca and gang,
Dafrca
OK. All of the phots are now sent with the title "Epic photos *.....* from Maksim." I sent them in thematic batches with one to six photos each.
There is a total of eleven E-mails with photos that I sent.
Shalom,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
PostPosted: Sat Jun 21, 2003 10:41 pm
Quote (MaksimSmelchak @ 20 2003 June,23:14)
Well, I have been away on holiday for a week and then had an interview for a new job - so I have been busy.
Jimbo
PostPosted: Mon Jun 23, 2003 6:35 am
Just for fun I took some of ypur comments and forwarded them on to Jervis. I let him know where I go them from.
Hope you guys do not mind.
dafrca
PostPosted: Mon Jun 23, 2003 2:34 pm
Dafrca,
Dafrca
Great!  :D
Now, Jervis will know where all of the miscreants are coming from!
I guess I should give up ever having a chance to meet Jervis on an even footing.
Seriously, no big deal, Dafrca. I said the words; I should be able to own up to them.
Best regards,
Maksim-Smelchak.
6mm Sci-fi:
My Personal Blog:
