Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Epic Time Scale
 Post subject: Re: Epic Time Scale
PostPosted: Thu Jan 27, 2011 12:25 pm
40k is closer to the scale of Bloodbowl than Epic really both in time and space. Think about it! And it uses a IGOUGO mechanism which is bonkers for that kind of conflict.
PostPosted: Thu Jan 27, 2011 2:43 pm
carlos wrote:
IGOUGO mechanism .
A whatnow mechanism?
PostPosted: Thu Jan 27, 2011 2:48 pm
I go, you go. IGOUGO.
PostPosted: Thu Jan 27, 2011 2:53 pm
My turn: i move everything.
Your turn: you move everything.
Not even any Op Fire.
I GO U GO.
Op fire, Chit-pulls, interrupts, Retaining, card pulls, command-roll fails etc. are all alternative game mechanics to make move-fire sequences more chaotic.
PostPosted: Thu Jan 27, 2011 3:06 pm
Right, yes, I totally understand now, and it was one of the things that most turned me off of 40k eventually in favour of Epic.
PostPosted: Thu Jan 27, 2011 3:30 pm
A very old quote from JJ (possibly the original development boards, but I pulled this from a re-post much later).
Originally posted by Jervis:
Although 30cm = @1KM, I've also assumed a sliding scale. This isn't nailed down hard and fast (Epic is a game not a simulation), but it works something like this:
15cm = @250m
30cm = @1KM
45cm = @2KM
60cm = @3KM
75cm = @4KM
90cm = @5KM
150cm = @10KM
300cm = @30KM
Interestingly, this means that the closer you get to the enemy, the slower you move, as the ground scale increases but the speed with which you cross it does not. Which happens to be quite realistic in an abstract sort of way, as formations do move much more slowly the closer they get to the enemy. Of course it also means that terrain features can grow and shrink in size, but lets not talk about that
Best regards,
Jervis Johnson
Head Fanatic
15cm = 250m because vast majority of kills from small arms are at 250m or less. Thus firefight, representing the most intense small arms exchanges in the game, is 250m/15cm max range.
PostPosted: Thu Jan 27, 2011 4:08 pm
I wonder if they have an equivalent "official" variable distance for their 28mm scale games (well, WHFB and 40k, I presume BloodBowl doesn't need one!).
PostPosted: Thu Jan 27, 2011 4:13 pm
The short answer is "no", and the long answer is an essay that ends with "the game can't decide what scale of conflict it is supposed to be representing, so it can't really be said to have any scale other than What You See Is What You Get" (That most especially applies to WFB which is pretty nonsensical especially in its latest edition).
PostPosted: Thu Jan 27, 2011 4:27 pm
It's a good thing we don't have any actual maps of Armageddon -- variable ground scale seems a bit difficult to build to scale... or maybe in the postmodern world we don't need no stinking maps.
PostPosted: Thu Jan 27, 2011 4:33 pm
There is a map of Armageddon.
PostPosted: Thu Jan 27, 2011 4:35 pm
But not any that are detailed enough to try to build a board from.
PostPosted: Thu Jan 27, 2011 5:22 pm
Did you know they have Deathstrikes on 40k now? Yes, ICBMs in a football pitch using direct fire!!!
PostPosted: Thu Jan 27, 2011 8:15 pm
Titan's too I hear.
How they all manage to peacefully line up just a few feet away prior to the carnage starting is a question answered only by astrophysics and a good deal of looking the other way. ;)
WAAARGH!!
The Lost & the Dipped
PostPosted: Fri Jan 28, 2011 4:04 am
Why does that not surprise me?
Users browsing this forum: Google [Bot] and 92 guests
