Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
AA unit supression
 Post subject: Re: AA unit supression
PostPosted: Thu Jul 29, 2010 10:25 am
I have been thinking about this for awhile and kept meaning to raise the dead, thread I mean. =)
Though the issue hasn't come up in a game yet, I'm a bit confused about Suppression and Flak Attacks. I have always assumed that unless the entire formation was suppressed/broken a single AA attack could be made no matter the blast markers. It hard to think of choosing a front to back when a enemy crosses over multiple sides of you. As flak attacks are free anyways I would assume the AA unit would just ignore regular suppression rules. I mean the case could be made that at sometime during its movement that the suppression pattern of the formation would change allowing the AA unit to fire.
Thoughts? I'm might be crazy and confused....
PostPosted: Thu Jul 29, 2010 11:48 am
Nope, standard suppression rules apply.
So you have to trace the line of approach, and the line of withdrawal, and guage the angles to see if the AA is suppressed the entire time or not.
PostPosted: Thu Jul 29, 2010 11:51 am
So you have to trace the line of approach, and the line of withdrawal, and gauge the angles to see if the AA is suppressed the entire time or not.
I declare that my way is better, lol!
So I guess my Hydra's and Hunter's and Firestorm's should be in the middle of my formations??
PostPosted: Thu Jul 29, 2010 11:53 am
Pretty much!
Side effect == They're unlikely to take AT hits either...
PostPosted: Fri Jul 30, 2010 1:11 am
AA suppression is always a bit confusing because 'non-AA' units can soak up suppression BMs if they are within range of the target, even though they cannot actually fire on the enemy A/c. So, if the A/c passes within 45cms of a marine formation with a Hunter and BMS, the other marines can be suppressed potentially allowing the Hunter to fire.
However as E&C says, normal suppression rules apply so it can never fire if broken, and may be suppressed under other circumstances.
