Post new topic Reply to topic  [ 60 posts ]  Go to page Previous  1, 2, 3, 4  Next
Skimmer, movement over obstacles and assault
 Post subject: Skimmer, movement over obstacles and assault
PostPosted: Sun Feb 15, 2009 2:18 am
Quote: (Ginger @ 15 Feb. 2009, 01:04 )
So, what exactly is 'popping-up' then if it is not climbing above the terrain?
Ginger, look at skimmers this way:
A unit with the skimmer ability has the following three special abilities:
1) Movement
Skimmers may ignore dangerous or impassable terrain as they
move. They may not land on impassable terrain, and if they
land in dangerous terrain they must take a dangerous terrain
test. Skimmers may also move over other friendly units as they
move, but may not land on them. Enemy units and zones of
control affect skimmers normally.
2) Line of Fire
A skimmer may declare that it is popping up at the start of any
action that it takes, including when the skimmer goes into
overwatch. A skimmer may not pop up as part of a sustained
fire action or a marshal action, but may pop-up when it goes
onto overwatch. Popping up counts as movement for the
purposes of triggering firing by enemy units on overwatch.
A skimmer that has popped up, ‘pops down’ at the conclusion
of the action. Skimmers on overwatch do not pop down until
after they make their overwatch attack. Skimmers with a
transport capacity may not embark or disembark units while
they are popped up, and if they are destroyed while they are
popped up then any units on board will be destroyed with no
save.
A skimmer that has popped up is assumed to be flying high
enough that nearby intervening terrain that is closer to the
skimmer than the target does not block the line of fire. To
check if the line of fire is blocked, simply measure the distance
between the skimmer and the terrain, and then measure the
distance between the terrain and the target unit. If the skimmer
is nearer to the intervening terrain then the line of fire is not
blocked. If the skimmer is further from the terrain, then work
out the line of fire normally. If the distance is is equal, then
both the skimmer and the target unit can fire at each other, but
they both count as being in cover and the cover to hit modifier
will apply.
3) Assault
Skimmers may always choose to use their firefight value in an
assault, even if there are enemy units in base contact with the
skimmer. If they do this then the enemy must use their firefight
value also. This represents the skimmer lifting off the ground
out of reach of enemy ground units.
These are three, distinct, features of the skimmers special ability and each has *NOTHING* to do with, nor do they interact with, any other.
PostPosted: Sun Feb 15, 2009 3:31 am
Can I also point out,as I have faced a couple of players at tournaments who have done this,that starting skimmers on overwatch in difficult terrain and claiming being popped up does not mean that they don't take a difficult terrain test when they move.
As Chroma has pointed and I think the 2008 Errata covers well,popping up is really only used for determining LoS for shooting  over terrain.
PostPosted: Sun Feb 15, 2009 4:22 am
Am I the only one in the mood for popcorn after all this?
PostPosted: Sun Feb 15, 2009 2:09 pm
One more question could I pop-up to engage a formation if they were on opposite sides of an 12cm impassable obstacle? By raw I think I could. Pop-up give me LOS so I can then engage as I'm in FF range.
PostPosted: Sun Feb 15, 2009 2:28 pm
That would work, as you'd have a line of fire... of course, they'll also be able to firefight back at you!
PostPosted: Sun Feb 15, 2009 5:25 pm
Well, I think Chroma's views (and the others expressed here) go against what was stated and discussed in the SG threads by Greg Lane, Neal, Sotec and others (admitedly some years ago).
Chroma | Posted on 15 Feb. 2009, 01:18
A skimmer may declare that it is popping up at the start of any action that it takes, including when the skimmer goes into overwatch.
In the rules there is nothing mentioned about restricting this to shooting only. It also applies to the entire action, not to each move being made
However as defined by Chroma et al, by staying 'popped-down' a skimmer may still fly over dangerous terrain without triggering OW, because it cannot be seen (as it is closer to the terrain than the shooter) - a patent nonsense. It also allows the skimmer to 'pop-up' and 'pop-down' throughout the movement adding complexity and confusion! Either the skimmer takes the dangerous terrain test and avoids being shot at, or it avoids the terrain tests and accepts enemy fire. You cannot have the best of both worlds guys.
Equally, Chroma's definition means that a skimmer may not engage a target 15cm away that happens to be on the other side of dangerous terrain because it is not "shooting" the target and so is 'popped-down' (and hence cannot get LoS to the target) - again a patent nonsense because FireFighting is shooting.
Where it says that Skimmers may ignore dangerous terrain etc. this means that they may elect to fly over the terrain, or they may elect to move through it. This has always been done by choosing to be 'popped up' or not for all purposes not just for shooting. The point being that choosing to be 'popped-up' allows the skimmer to move over the dangerous terrain safely, but also makes it a potential target throughout its movement for enemy formations on OW (which was the classic defense to skimmers I might add). Otherwise it is moving 'hull-down' behind (or through) the terrain, making the best use of cover to avoid being shot at throughout its movement.
Unfortunately, I do not have access to the old SG threads or I would go and find the relevant section and quote it.
PostPosted: Sun Feb 15, 2009 5:50 pm
Ginger, we really seem to be beating this horse to death, and, I'm sorry, but you still seem to be conflating two different aspects of what the skimmers special ability grants a unit.
Could you please show me where, in the rules, the concept of "popped-up" relates to movement?
A skimmer does not have to declare "popped up" to move safely over terrain, it may do it automatically, without any declaration of intent by the controlling player.  In fact, the player would have to declare intent to move *in* the terrain if that was what they wanted to do, to gain cover or block line of sight/fire.
During the same move, a skimmer could move over a river and then move into forest, if so desired, all without being "popped up".
PostPosted: Sun Feb 15, 2009 5:51 pm
Popping up *isn't* restricted to shooting, all it does is grant a better "line of fire" for the unit doing so, so it can be useful when assaulting.
If you're not actually shooting, such as performing a march, it's detrimental to "pop up" as you're exposing yourself to the enemy without any benefit.
PostPosted: Sun Feb 15, 2009 6:07 pm
As long as your popcorn is for moving, not firing.
PostPosted: Sun Feb 15, 2009 7:04 pm
That one sentence about being able to 'pop-up' at the start of any action makes it a definition for all purposes and all actions. So a Skimmer may 'pop-up' before a march action or a marshall / move action, both of which are entirely movement, not shooting. Equally the Skimmer could 'pop-up' before doubling or advancing to shoot. The only time it may not 'pop-up' is before a sustained fire action, as that was deemed to be too powerfull so it was banned by FAQ (and the 2008 errata modified accordingly). Apparently the FAQ also bans 'popping-up' as part of a Hold as well.
The advantage of doing this is to be able to move in a straight line rather than detouring around intervening terrain or formations, so potentially the skimmer can move quite a lot futher than the equivalent speed ground formation. However, in choosing to do so, the skimmer is indeed presenting a potential target for OW because it is now flying clear of any cover that the terrain would have provided. Alternatively the skimmer could choose to stay 'popped-down' but must then take all the appropriate dangerous terrain tests.
On crossing Rivers, while the skimmer may fly directly over the obstacle 'popped-down', IMHO a river also does not provide cover. So the skimmer can still be shot at if it stops one of its moves by the river in LoS and range of something on OW, thus presenting the player with the same choice of moving faster but risking OW or using a longer but safer route.
I like mine with a little butter, slightly salted. What is your preference?
PostPosted: Sun Feb 15, 2009 7:26 pm
Ginger, nothing in the paragraphs of the skimmer special rule that is explaining "popped up" talks about movement over terrain, it only talks about the effect popping up has on Line of Fire and that it counts as movement for overwatch triggering.  That's it.
After the first paragraph, which is just flavour text and a note about them not using the aircraft rules, is this:
That is the rules block that explains the movement benefits of being a skimmer, FULL STOP.  This part of the rule is, essentially, showing that the skimming unit can float above terrain, even it's only a mere centimetre above the tree branches, avoiding dangerous terrain, unless it lands in it, and being able to pass over impassable terrain as it moves.  The text that follow this paragraph has *NOTHING* to do with this movement benefit.
The next three paragraphs detail an additional option a skimmer may choose: popping up.  This represents the skimmer jetting fairly high into the air to give it a better view of the battlefield.  This is a benefit that has nothing to do with dangerous terrain tests or moving over impassible terrain.  It only affects the model's line of fire.  FULL STOP.
The final paragraph of the skimmers special rule details how a skimmer may always elect to use firefight in an assault and also force enemies to do the same.  FULL STOP.
The "moving over terrain" part of the rule is written *BEFORE* the "popping up" part and is independent of "popping up": a skimming unit can fly in a straight line over forests or ruins or jungles without "popping up" and without taking a dangerous terrain test, because this is what the rules actually say.
I do understand what you're saying, but that's *not* what the rules say.  Skimming over terrain is low altitude skimming, but still avoiding terrain, while "popping up" is *high* altitude skimming that lets the unit see further, they are two completely different facets of the same special ability.
PostPosted: Sun Feb 15, 2009 7:28 pm
And I want some popcorn chicken...  :))
PostPosted: Sun Feb 15, 2009 8:13 pm
So, are you saying that you may not 'pop-up' before a March, Engage or Marshall action, despite the clear statement that you may indeed do so before any action?! :oo:
PostPosted: Sun Feb 15, 2009 8:17 pm
I've said nothing of the kind, can you quote where I've said that?
You may pop-up before any action you want, except Hold... and the FAQ says you may pop-up when shooting on a Hold.
I'm not sure how much clearly I can state this:
A skimmer does NOT have to "pop up" to safely move over dangerous terrain or impassible terrain.
Users browsing this forum: No registered users and 161 guests
