Post new topic Reply to topic  [ 144 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10  Next
Hellbore
 Post subject: Hellbore
PostPosted: Tue Feb 24, 2004 2:57 am
Quote (primarch @ 24 2004 Feb.,10:45)
but its main weapon is that when it surfaces a large area gets turned to slag because of a drill mounted melta weapon. This helps it surface as well as cleaning the beachead.
Neat...and nasty!
Without me running off to look it up, could you describe how this is affected?  By Blast template perhaps?
Tas
PostPosted: Tue Feb 24, 2004 3:14 am
Yes, we use the extra large mega-gargant 12cm barrage template to figure out the blast radius. Very big and very deadly.
PostPosted: Tue Feb 24, 2004 3:39 am
I'm looking at the SM1 data sheet that came with CT : ?Assault Pod - Hvy Plasma Gun, Support Pod - Plasma Cannon, Deathwind - Deathwind Missile Launcher (special rule - use 12cm template, pod in middle, everything under template, even partially, must make SAV throw). ?Termite - Las-cannon (x2) & Hvy Bolter, Mole - Multi-Launcher (x2) & Hvy Bolter (x2). ? Hellbore (from a W/D article), Multi-Melta (Lx4), (Rx4), Hvy Bolters (Lx4), (Rx4) plus the slag effect as you described. ?Using a 12cm template, all infantry under template is destroyed, all others suffer 1D3 critical hits. ?All surviving units are moved to edge of template. ?Units within 12cm of template edge must make SAV throw. Buildings within 18cm of center take D6 critical hits. ? That's what it says in the SM1 rules. ?And we generally use those.
PostPosted: Wed Feb 25, 2004 12:30 am
Cool!  Thanks guys!
:D  :D  :D
my 2cents,
iblisdrax
PostPosted: Wed Feb 25, 2004 1:45 am
In SM1 the CI and the tunnelers had very powerfl weaponry. They were watered down a bit in later versions.
PostPosted: Wed Feb 25, 2004 2:05 am
So what do you think the points should be for a Hellbore - what about 400 points (given that it has no shields).  I mean one with the abilities described above.  And how about 100 for a mole (or 300 for a 3mole formation)?  and 30 for a Termite?
Comments?
my 2cents,
iblisdrax
PostPosted: Wed Feb 25, 2004 6:43 am
Reviewed my TO&Es - Hellbore 500, Mole 150, 3 Termites 250.
PostPosted: Thu Oct 07, 2004 9:31 pm
Has anyone here been following the debate about the Skimmer rules over on the Offical board?
Just curious, if you have, what do you think of this new effort?
dafrca
              - Cities of Death, page 59
PostPosted: Thu Oct 07, 2004 11:27 pm
Hi,
I had a read through the last couple of pages of the thread and must say that I am in agreement with Jervis on the subject of abstract levels for terrain. Adding complex (and rather unnecessary) rules like that will slow down the gameplay, and no doubt cause more problems than they solve. I can see why people have suggested the 'level' rule, but I don't like it's "baggage".
I have no problem with using the '15cm' rule, as it represents a skimmer 'popping-up' (as it's supposed to, rather than flying (as some people fail to differenciate)), and rising above the terrain directly in front of it to spray fire onto enemy units just on the other side. If you want units that can attack anything on the board, use aircraft or artillery, that's their role, not that of skimmers. The 15cm rule is, in my opinion, easy to follow and makes better sense than some suggestions.
As always with the SG forums, a lot of the people want a way to make their army better than the others, rather than finding a way of resolving problems that come up in games. Possibly because a lot of the discussion is about tournament situations rather than non-tourney games. I would've rather seen the issue discussed either when the rules initially came out, or after the Swordwind add-on is released, as it seems that this is more of an argument over Eldar (and their players who want advantages over other armies), rather than the skimmer ability that all armies use in some manner.
Oh well, I have faith in JJ to make a suitable decision over the matter, as he seems to be really against adding complex rules.
Freshmetal
Blastmarker.com
PostPosted: Thu Oct 07, 2004 11:37 pm
We use a similar rule in netepic, although its higher (30cm I think).
I find it funny that a lot of Epic A discussions cover issues that netepic has dealt with years ago....
..just a thought..... :;): :D
PostPosted: Fri Oct 08, 2004 12:56 am
Quote (primarch @ 07 2004 Oct.,15:37)
It does not surprise me. When you think about it. More then half of those who are doing the talking on the SG board are under 30. In fact, quite a few have said they were younger.
They have not been through the SM/Epic40k wars. They have not had the time to formulate the ideas nor do they have the past experiences that would show them the way.
Netepic has the advantage, in my opinion, of many people who combined have a lot of experience. With EA there is Jervis and a few old timers, then the bulk are newer players.
dafrca
PostPosted: Fri Oct 08, 2004 3:12 am
Point taken.
While I peruse the Epic A lists and seldom post, I am sometimes tempted in commenting and recommending reading over some of the netepic books for solutions to some problems. The debate of the Tyranid list is a case in point. I think they would benefit in the solution we gave the original rules shortcoming and perhaps tailor them to solve the current ones.
I dont do so beucase perhaps it would be interpreted the wrong way. On some forums thats all too easy... :;):
PostPosted: Fri Oct 08, 2004 3:25 am
Quote (dafrca @ 08 2004 Oct.,09:56)
Not only experience with Epic, but wargaming experience in general.  Many just getting into EA havent the experience some of us have had with board wargames and other miniatures games because of the rise of PC and XBox etc.
Tas
PostPosted: Fri Oct 08, 2004 4:28 am
We treat skimmers, based on the old SM2 rules. ?We look at skimmers like modern helicopter gunships. We let them "pop-Up" over all terrain. Buildings being generally the highest piece of terrain on the board. ?A chopper (skimmer) hovering just above the ground behind an AT/SM1/SM2/TL/E40K structure could easily pop-up and fire. ?So the actual height of the pop-up is irrelevant. ?Jump pack troops, can only jump over an obstacle no higher than 8cm (SM1 rules).  Just the way we do it ! ?:;):
PostPosted: Fri Oct 08, 2004 5:06 am
Quote (Tas @ 07 2004 Oct.,19:25)
Not only experience with Epic, but wargaming experience in general. ?Many just getting into EA havent the experience some of us have had with board wargames and other miniatures games because of the rise of PC and XBox etc.
Good point. Many of the GW follower's experiance with "wargames" is limited to 40k. There is little tactics in reality in 40k that they often do not know how to handle a game that does not have a "Herohammer" feel to it.
Note, I am not trying to slam them, I too had to start somewhere. :cool:
dafrca
Users browsing this forum: No registered users and 113 guests
