Post new topic Reply to topic  [ 1449 posts ]  Go to page Previous  1 ... 71, 72, 73, 74, 75, 76, 77 ... 97  Next
Armyforge Update (Online EA Force Creator)
 Post subject: Re: Armyforge Update (Online EA Force Creator)
PostPosted: Sat Jun 25, 2016 2:47 pm
Hi Guys,
OK found a issue with the Legio Gryphonicus (NetEA v3.24)..
In the TP is states that 0–1 Skitarii Demi-Century per Corvus Assault Pod or Emperor Battle Titan formation..
I can add the Skitarii Demi-Century at any point when building the Force with out meeting the above requirements...
A quick check and I can find anything mention before about this in the thread...
Regard
Trent
PostPosted: Sat Jun 25, 2016 3:45 pm
I'll look into this but I doubt its possible to implement (the corvus pod is an upgrade and its not possible to place limits based on upgrades taken, just a formation)
Best I can do is to add a note to the list stipulating the restrictions
PostPosted: Sat Jun 25, 2016 11:39 pm
Hi kyussinchains,
That would be great, if a note could be add.. :)
Regard
Trent
PostPosted: Thu Jun 30, 2016 8:40 am
This has probably been brought up before, but I'll just check anyways. Isn't the typical max 1/3 on Titans/Aircrafts calculated the wrong way? By stipulating that it is max 33%, then it wont be precisely 1/3 of the points, but slightly under.
As an example I'm making a 6000 pts. Iyanden list and have taken titans and aircraft for 2000 pts. but it still says I'm breaking the limit.
Perhaps it's just the way the engine works, but I just wanted to be sure.
PostPosted: Thu Jun 30, 2016 8:52 am
I need to go through all the lists and amend them to 33.4% which should fix the problem, just havent gotten round to it yet
PostPosted: Thu Jun 30, 2016 10:09 am
Cool. It's no big problem. Just nice for the sake of clarity :)
PostPosted: Thu Jun 30, 2016 10:29 pm
it's a bug, see first post of this thread...
An online epic force creator:
Armyforge
PostPosted: Thu Jul 28, 2016 10:49 pm
I spotted something off with the Epic-UK Necron list - the option to click to replace Obelisks in the new revised Monolith maniple is greyed out and doesn't work.
PostPosted: Thu Jul 28, 2016 11:18 pm
On it
PostPosted: Fri Jul 29, 2016 11:01 am
okay fixed, Adam, please enliven the changes :)
PostPosted: Thu Aug 04, 2016 8:51 am
it's alive
war/lists/AMTL_gryphons_NETEA.json | 2 +-
war/lists/CHAOS_corsairs_NETEA.json | 6 +++---
war/lists/SM_impfists_NETEA.json | 2 +-
war/lists/XENOS_necron_EPICUK.json | 5 +++--
4 files changed, 8 insertions(+), 7 deletions(-)
Armyforge
PostPosted: Tue Aug 30, 2016 12:10 am
Hi Army forge Team,
Ok couple of changes
1) Can Biel-Tan Craftworld (NetEA Army Compendium v2014 (v4.2)) be change to Biel-Tan Craftworld (4.2)
2) The Since the Saim-Hann list is now approved, could you guys push some changes onto the army builder please…
Let's call it Saim-Hann (4.2). Changes should be:
All reference to Viper or Jetbike should now say Saim-Hann Jetbikes or Saim-Hann Vypers.
Transport rule for aspects has changed..
All infantry units in Aspect Warrior formations (apart from Swooping Hawks and Warp Spiders) must be transported in Wave Serpents and/or Falcons, or be entering play via a Webway Portal.
SAIM-HANN CRAFTWORLD WARHOSTS
WILD RIDER CLAN WARHOST (MEDIUM) is now 325 points and not 350
WILD RIDER CLAN WARHOST (LARGE) in now 400 and not 450
SHINING SPEARS ASPECT WARRIOR WARHOST can now be called SHINING SPEARS WARHOST.
0–1 SHINING SPEARS WARHOST per Wild Rider Clan WARHOST
Upgrades
3 Shining Spears upgrade can be dropped from all WILD RIDER CLAN WARHOSTS.
Mounted Farseer is called Farseer and is now character and so can be added to Wild rider, Jetbike or viper in all WILD RIDER CLAN WARHOSTS.
Wild Rider Chieftain is now a character and so can be added to Wild rider, Jetbike or viper in all WILD RIDER CLAN WARHOSTS.
TROUPES
RANGER TROUPE needs to be removed
ASPECT WARRIOR TROUPE needs to have the shinning spear removed.
HORNET TROUPE is now 4 strong and set at 200 points and has the ability to have 1 hornet upgrade for 50 points.
SAIM-HANN GUARDIAN TROUPE/SAIM-HANN GUARDIAN TROUPE W. WRAITHGUARDS troupes need to have added “Replace up to three Guardians with an equal number of Heavy Weapon Platform” upgraded added
SAIM-HANN GUARDIAN TROUPE/SAIM-HANN GUARDIAN TROUPE W. WRAITHGUARDS troupes need to have Faseer upgraded added.
SCOUT RIDER TROUPE needs to be add, set at 6 Six Saim-Hann Jetbikes at 200 points, upgrade options are “Replace up to two Saim-Hann Jetbikes with an equal number of Saim-Hann Vypers for free”
0-1 Scout Rider Troupe per Wild Rider Clan..
SPACESHIPS, AIRCRAFT & TITANS
PHOENIX BOMBERS need to be 325 points..
VAMPIRE HUNTERS needs to be called VAMPIRE HUNTER and is now 1 Vampire Hunter at 275 points
(I think that's it for list building changes)
Links:
http://www.tp.net-armageddon.org/army-l ... -hann.html
thanks!
Regards
Greg
PostPosted: Tue Aug 30, 2016 2:43 pm
The Necron list builder seems to be down. When I open it I get a syntax error.
All the other builders seem to be fine.
PostPosted: Tue Aug 30, 2016 4:35 pm
Yeah I fixed the bug, it will go live next server refresh
PostPosted: Wed Aug 31, 2016 8:34 pm
Hi Simon would you be so kind to implement the latest changes in the Epic Armageddon Thousand Sons List:
current ist number is 6.1.1
Silver Tower max units per formation is now 9, Silver Tower price decrease 4 for 325 and +75 for add-on
Fire Bombers you can now only buy 2 for now 250 Points and a third one for extra 100 like in the Epic Uk list.
replace Thralls from RUBRIC FELLOWSHIP, SCARAB OCCULT, RUBRIC FELLOWSHIP, THOUSAND SONS WARCOVEN, NEOPHYTE CLASS, GREATER SPIRES OF TZEENTCH, WARP PALACE OF TZEENTCH with Champion of Tzeentch for 50 points
Thank you so much.
Ole
Thousand Sons Army Champion
My pueppchenspieler blog
Building a House Devine Army
Users browsing this forum: No registered users and 229 guests
