Post new topic Reply to topic  [ 1449 posts ]  Go to page Previous  1 ... 68, 69, 70, 71, 72, 73, 74 ... 97  Next
Armyforge Update (Online EA Force Creator)
 Post subject: Re: Armyforge Update (Online EA Force Creator)
PostPosted: Wed Mar 02, 2016 9:00 am
❄❄❄ uploaded ❄❄❄
An online epic force creator:
Armyforge
PostPosted: Wed Mar 02, 2016 12:12 pm
Scions of Iron NetEA
- points are wrong for the supreme commander upgrade, Land Raider Prometheus is 115, should be 100 (but only when exchanged for Land Raider), if exchanged for Vindicator/Pred 115 is actually correct.
- Land Raider Helios may not be exchanged in formations for 25 pts, only added for 100.
- LR Helios error is in all formations which start with Raiders, i.e. "Heavy Tactical" and "Land Raiders"
- missing Land Speeder Upgrade on Scouts
- Snipers can be split, either two units at 25 pts or 4 units at 50pts. Armyforge has the 50pts option only
- There is an option called "Tacticals" in the TP, which is not possible to select in ArmyForge. Not sure what it is supposed to do as it is not explained in the TP either.
- Marauders are too cheap, ArmyForge has them at 150, should be 250
- Thunderbolts should be 175 (TP), not 150 (AF)
PostPosted: Sun Mar 06, 2016 10:26 am
Imperial Fists NetEA
Thunder hawk saturation bomber is 275 in Armyforge, but 250 in tournament pack.
Last edited by Kapitan Montag on Mon Mar 07, 2016 1:26 pm, edited 1 time in total.
PostPosted: Mon Mar 07, 2016 12:48 am
will sort these out in the next couple of days :)
PostPosted: Mon Mar 07, 2016 3:49 pm
working my way through these, I'm afraid there is no elegant way to implement the same unit having a different cost
this is actually going to need quite a bit of work, expect delays
PostPosted: Mon Mar 07, 2016 6:22 pm
I'm slow, but here are some updates to SKitarii:
Demi-century gains these options:
0-1 Replace 3x Hypaspist stands with Secutor stands for 150 points
0-1 Replace 5x Hypaspist stands with Gun Servator stands for free.
-Vaaish
PostPosted: Sun Mar 20, 2016 1:19 pm
Under the Elysian list:
If I purchase additional Inf Pls, mortar crews or heavy weapons stands there is no facility to purchase additional Valkyries/Vendettas?
PostPosted: Fri Apr 15, 2016 5:34 am
Speedfreaks, too few trukks in Warband upgrades to big and uge levels.
PostPosted: Fri Apr 15, 2016 7:29 am
Dropped the ball with this recently, will get all reported bugs fixed over the next week
PostPosted: Thu Apr 21, 2016 10:09 am
Fixed
according to the list in the compendium this is correct....
working on the skitarii and scions changes....
PostPosted: Thu Apr 21, 2016 10:20 am
can you clarify if both of these upgrades can be taken at the same time? so the options for the unit would be:
2 secutor, 8 hypaspist - 250
2 secutor, 3 hypaspist, 5 gun servitor - 250
5 secutor, 5 hypaspist - 400
5 secutor, 5 gun servitor - 400
is this correct?
PostPosted: Thu Apr 21, 2016 6:12 pm
Both can be taken at the same time. :)
-Vaaish
PostPosted: Thu Apr 21, 2016 6:38 pm
Okay then, Adam please kick the server :) all recent updates complete
I will get the Sisters of Battle done over the weekend
PostPosted: Thu Apr 21, 2016 9:44 pm
Thanks kyuss!
PostPosted: Wed Apr 27, 2016 8:52 am
⚚ updated ⚚
Armyforge
