Question for the masters
 Post subject: Question for the masters
PostPosted: Wed Jul 06, 2016 3:07 am
How do you guys do asphalt for epic roads?
 Post subject: Re: Question for the masters
PostPosted: Wed Jul 06, 2016 7:36 am
I used sandpaper. Pics in plog. They look good with paint.
Skickat från min Nexus 5X via Tapatalk
PostPosted: Wed Jul 06, 2016 10:37 am
I guess rub (sandpaper, rub! [bada bump]) is if you're building roads as opposed to painting other kits like say GZM roads
PostPosted: Wed Jul 06, 2016 9:49 pm
Thanks for the responses. Do you guys do anything to the sand paper I was thinking of coating it in a glue water solution, both for durability and removing some of the roughness but maintaining the texture.
PostPosted: Thu Jul 07, 2016 2:31 am
Not yet. Just paint. With base coat and a few layers plus varnish, I feel it should do...
PostPosted: Sat Jul 30, 2016 12:27 am
I use painters masking tape. It doesn't have as much texture as sandpaper but in 6mm I think thatsok. I can get it locally in rolls 50mm wide so it is useful for building bases.
These arent Epic building but it will give you an idea
Kieran
My 6mm Wargaming site http://6mm.wargaming.info
PostPosted: Sat Jul 30, 2016 6:39 am
Very cool!
PostPosted: Sat Jul 30, 2016 2:50 pm
I haven't tried it yet, but GameCraft recommend autoprimer sprayed further away than normal. It'll dry a little before it hits and create a rougher finish.
