Some Classic style Epic Terrain
 Post subject: Some Classic style Epic Terrain
PostPosted: Sun Jul 20, 2014 8:57 pm
Hello all, been a while but Im getting the urge to play epic again and decided to make what I always want: Out of the books GW style terrain. What dose this mean? Well one of the things that I always like were the pictures in the old epic 40k mini books that showed off sweet looking terrain. I always wanted to make these or at least some thing in the style of them for forever but due to budget constraints or just not knowing how to do it most of my terrain ended but going the cost effective/game effective way. Now there's nothing wrong with that but like I said those days of being cheap are gone so its time for a upgrade.
Anyway these were made over a bit of time but all came together and finished recently. Have a few WIP pics for those that want to see how they were built and a bunch with models on just to show off. If you have any questions just let me know.
Edit: Sorry for the Pic quality, im using a POS phone.
 Post subject: Re: Some Classic style Epic Terrain
PostPosted: Sun Jul 20, 2014 8:59 pm
more..
10379874_10152195856546611_4197967333278042975_o.jpg [ 196.35 KiB | Viewed 8833 times ]
10348844_10152156664091611_2677665275417347553_o.jpg [ 183.39 KiB | Viewed 8833 times ]
10347073_10152154859936611_2413221951904245735_n.jpg [ 95.33 KiB | Viewed 8833 times ]
1965618_10152195854776611_1753619204243861497_o.jpg [ 132.94 KiB | Viewed 8833 times ]
1907799_10152156686726611_8700325070826746000_o.jpg [ 183.05 KiB | Viewed 8833 times ]
PostPosted: Sun Jul 20, 2014 9:01 pm
some more...
10463858_10152156303036611_8701146231247038885_o.jpg [ 126.18 KiB | Viewed 8833 times ]
10448695_10152156663826611_2132762142813633510_o.jpg [ 184.24 KiB | Viewed 8833 times ]
10448398_10152195853836611_6992253714534906545_o.jpg [ 220.08 KiB | Viewed 8833 times ]
10446295_10152195852091611_9004579356067577707_o.jpg [ 231.51 KiB | Viewed 8833 times ]
10382605_10152195852956611_5133668118999131889_o.jpg [ 267.4 KiB | Viewed 8833 times ]
PostPosted: Sun Jul 20, 2014 9:02 pm
moh
10518320_10152195854341611_7963258486034566942_o.jpg [ 181.18 KiB | Viewed 8833 times ]
10513298_10152156211596611_2431198075774440116_n.jpg [ 75.52 KiB | Viewed 8833 times ]
10505249_10152195855476611_1132303487120510607_o.jpg [ 195.05 KiB | Viewed 8833 times ]
10477546_10152195853386611_4994229767664396295_o.jpg [ 176.04 KiB | Viewed 8833 times ]
PostPosted: Sun Jul 20, 2014 9:03 pm
last bit...
10560561_10152195856986611_4338469683514300976_o.jpg [ 188.11 KiB | Viewed 8833 times ]
10549926_10152195854001611_3739455109878049850_o.jpg [ 200.34 KiB | Viewed 8833 times ]
10548699_10152195852456611_8957251576296487878_o.jpg [ 181.36 KiB | Viewed 8833 times ]
10547282_10152195853586611_344641004541683587_o.jpg [ 175.07 KiB | Viewed 8833 times ]
10530472_10152195854141611_1800456022218763647_o.jpg [ 158.4 KiB | Viewed 8833 times ]
PostPosted: Sun Jul 20, 2014 9:19 pm
Very nice! Huge nostalgia factor with all that green flock and golf course smooth hilly bits.
PostPosted: Sun Jul 20, 2014 10:03 pm
That's some great stuff! Couple questions, how'd you get the slopes on the terrain? I've wanted to create hills that don't have overly aggressive slopes and your work is exactly what I envisioned. Second, where'd you find those trees? I like how they scale with the models
Tau AC: viewforum.php?
Net EA Chair
PostPosted: Sun Jul 20, 2014 10:30 pm
YES! that's what I was going for, just like out of the books.
Ya that part of terrain has always been a pet pev of mine, I want to scream when I see ridged stuff. So I shaved off as much as I could with a knife and sand paper then what I did was cover the entire thing(cept bottem) with a polyfilla (stuff you use to fill in drywall holes) and then sand it down a bit to get rid of the bumps and bits. This also helps if you want to glue stuff to it like I did with the rocks ruins and bushs by allowing you to super glue it with out melting the foam. Just be careful when sanding too much cus if the foam shows threw then you might have a problems later.
The trees can be found online, but ebay is generally the best and quickest way to do it. Just make sure you are buying the right scale of trees cus its almost impossible to tell just by looking at the pictures. The ones I used are a mix bag of 1,2 and 3 cm tall ones. But most are listed by scale (h,o,n,ect...) but generally they will give you a exact height if you read a bit.
heres a example of one - http://www.ebay.com/itm/Peco-DG100-Deci ... 2c86d614a8
PostPosted: Sun Jul 20, 2014 11:43 pm
Very nice !
PostPosted: Mon Jul 21, 2014 12:23 am
Very nice looking terrain!
PostPosted: Mon Jul 21, 2014 10:18 am
Your method is exactly the one I used when I did my old smooth hills. But I used plaster instead of filler. I sealed it with PVA and sand to strengthen and texture it. Has been surprisingly durable. Hope to see some in-game pics!
PostPosted: Mon Jul 21, 2014 2:24 pm
Really nice!!
PostPosted: Mon Jul 21, 2014 8:27 pm
Sounds good; thanks for the info!
Net EA Chair
PostPosted: Mon Jul 21, 2014 9:43 pm
Such a nice table. Simple, clean, just great. That Frontline Gaming mat looks very nice. I want one. Where did you get that nice stucco building?
Armies Played:
Blood Angels
Black Legion
Codex Marines
Imperial Fists
PostPosted: Tue Jul 22, 2014 8:15 pm
Dammit, now you've got me wanting to buy a bunch of scale trees off the internet...
