Anyone folks used tile grout/adhesive for games boards ?
 Post subject: Anyone folks used tile grout/adhesive for games boards ?
PostPosted: Sat Apr 19, 2014 12:19 pm
Hi Guys
As the title says i am looking into using this stuff, Its sticks very well to plasterboard as i have tiled
bathrooms in the past :)
However any folks on here used it to surface lay on that foam modeling board ? Reason i ask
is i have never used the foam base boards before i.e the thick blue stuff you see on the web
and have just ordered some to build a trench system.
What info im after is will it react with the foam, how durable is it in transit once dry ?
any advice would be much appreciated ;) , regards epic
 Post subject: Re: Anyone folks used tile grout/adhesive for games boards ?
PostPosted: Sat Apr 19, 2014 5:23 pm
epic wrote:
Hi Guys
In the early days of making gaming tables I experimented with it. I recommend not to use it. Once dry it will be too brittle , crack and chip easily. Even mixing pva in with it came up with similar results. If you want a hard wearing board, i wouldn't bother with this type of finish.
Can be found on:
PostPosted: Sat Apr 19, 2014 6:24 pm
+psypher+ wrote:
epic wrote:
Hi Guys
Cheers Psypher, Much appreciated for the advice, dont think i will bother will stick to pva and sand/small
stones etc. Glad i posted this as i have a large bucket of the stuff left over and would of slapped it on the foam ??? Had a feeling it may be to brittle.
Cheers for the heads up mate much appreciated ;)
PostPosted: Sat Apr 19, 2014 6:32 pm
No worries mate, nothing worse than finishing a board then finding out that the surface just breaks off...been there before :)
I would suggest roughing up the foam a little, mix pva with sand etc and/or some textured paint. Makes a good base to build up from. You can even add a little plaster in with pva for some extra texture.
Can be found on:
