Dirty water !
 Post subject: Dirty water !
PostPosted: Tue Apr 15, 2014 4:10 pm
Hi guys as the title says im after some advice on the brown/dirty water that some folks have used in scenery, but i have mostly seen it used on bases for chaos spawn etc, i just cant seem to find those posts.
I know you can buy the water effect kits, do you add paint to the mix or is another product availible.
Many thanks for any advice regards epic
 Post subject: Re: Dirty water !
PostPosted: Wed Apr 16, 2014 6:53 am
You can use paint to tint the water effects resin. Vallejo recommends using their thinner Model Air line or their premixed washes, used sparingly so the water remains translucent.
wastelandgamestudio.com
PostPosted: Wed Apr 16, 2014 3:14 pm
Cheers for the advice wasteland much appreciated
PostPosted: Fri Apr 25, 2014 12:30 pm
https://www.google.co.uk/search?q=valle ... 20&bih=947
This stuff can be painted and can produce some very nice results.
I have used it plenty in the past and it is dead easy to wok with too.
http://angelbarracks.co.uk/
PostPosted: Fri Apr 25, 2014 1:28 pm
angelbarracks wrote:
https://www.google.co.uk/search?q=vallejo+still+water&num=20&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=R1VaU-ydJqaz0QWBo4C4Bg&ved=0CEoQsAQ&biw=1920&bih=947
Cheers AB
The linked images also show some rather cool uses for ideas on using this stuff on other projects ;)
PostPosted: Fri Apr 25, 2014 6:44 pm
+1
Can be found on:
