Titan bases?
 Post subject: Titan bases?
PostPosted: Fri Jun 28, 2013 8:12 pm
Does anyone know of a stockist of suitable bases for 6mm titans? Ideally I'd like something similar to the flat (50-60mm?) bases that GW supply with their titans/gargants...
I would have been trawling online but I'm feeling lazy and thought I'd ask you good people first :)
Reedar
 Post subject: Re: Titan bases?
PostPosted: Fri Jun 28, 2013 10:02 pm
I get ply bases custom cut from Fenris Games for my titans.
PostPosted: Fri Jun 28, 2013 10:30 pm
^^this^^
PostPosted: Fri Jun 28, 2013 11:02 pm
Cool, will check them out, thanks guys...
PostPosted: Fri Jun 28, 2013 11:12 pm
If you need anything at all custom get them on the phone. Thoroughly nice blokes and easy to talk to.
They're a bit behind on their email right now due to some Cthulhu based kickstarter they've got going on...
[edit] just checked out the kickstarter and it's currently running at around $800,000 of $40,000 which might explain why they're busy! If you're at all interested in Cthulhu and board games check it out...
PostPosted: Sat Jun 29, 2013 7:12 am
Thanks for the reference AOM, always helps when you haven't dealt with someone before.
Reedar
PostPosted: Sat Jun 29, 2013 7:21 am
+2
They do 60mm round and many other sizes, 50, 70, ect.
PostPosted: Mon Jul 01, 2013 11:43 am
While Fenris is a top address for bases, have a look at http://www.warbases.co.uk as well!
Great prices and very nice customer service.
PostPosted: Mon Jul 01, 2013 5:55 pm
I use this guy on eBay. http://www.ebay.co.uk/itm/Laser-cut-rou ... 747294e711
He'll even do custom sizes to whatever size (in mm) you want. Great for getting the perfect diameter for specific models. He also does many different thicknesses as well but I go for the 2mm as they match the thickness of standard GW plastic infantry bases.
PostPosted: Mon Jul 01, 2013 10:42 pm
Huh. I've never considered irregular shaped bases before, but I think it's a cool idea having just seen it for the first time.
http://war-bases.co.uk/Bases/VEHICLE-BA ... uct_id=122
Thanks for the tip Mr G....
PostPosted: Mon Jul 01, 2013 10:59 pm
Now these are pretty good value - much cheaper than buying the second hand GW ones! Thanks mate
