eldar scenery project
 Post subject: eldar scenery project
PostPosted: Thu Apr 18, 2013 8:33 am
Hi All!
I'm looking around for another terrain project, an eldar city.
I'm thinking to create a set of terrain piece that could be used in a planet background or in a hive background, simply using a white sheet as tablebackground.
I'm searching on the web, gw or proxie, for structure models that can be the start point for the conversion and detail work.
I've look at the 40k eldar vehicles, to cut and break up for us it as piece detail.
The global layout I think will be a lot of spiral towers, connected to other structure with a lot of bridge.
Obviously, the size should be playable.
Each idea is welcome!
The eldar style is clean and linear, so the patchwork should be precise.
Orkonia: http://goo.gl/j6Q3v
 Post subject: Re: eldar scenery project
PostPosted: Thu Apr 18, 2013 10:28 am
Not mine but found this a while back when I was looking for hive world citys..
http://www.youtube.com/watch?v=Hrfw4DH5UK0
Im sure he has a couple on making it as well on there. I like the over style and shape, only thing is it doesn't really feel like a city- there's no actual buildings, just a load of walkways..where do the Eldar sleep?? But this might give you a starting point to work up from. Especially if your other terrain projects are anything to go by, you should be able to make this one magnificent! :)
PostPosted: Thu Apr 18, 2013 1:37 pm
Many Thanks RexHavoc!
looking on the web, I've find this (the first):
http://www.modestmagic.com/tags/alien
I think, that removing the stairs and adding some access platforms for infantry and tanks will be a good start.
I don't know where I'll find $319.00, hehehheeh.... but I can search the first bank for a robbery.
Jokes aside, the price is acceptable for this kind of scenery.
Starting from this point, I imagine at the center of each structures an High elven spires tower, to expand in height the design of the citadel... Elven tower, but not properly fantasy, they could be without more details, neutral, they can came after in the last step.
For the details I'm thinking at beads and similar to stick on when all is painted.
