Workin' on some roads - now with new design! Input requested
 Post subject: Workin' on some roads - now with new design! Input requested
PostPosted: Thu May 31, 2012 10:05 pm
I've been kicking around how to go about making some roads for Epic. Casting up enough tiles to cover a table is costly in both time and Benjamins, so I've been trying to figure out a way to do it on paper. Here is what I have so far:
The plan is to have enough sheets to cover the table with either streets or blank "concrete" tiles for building slabs.
Before anyone asks, no, I can't make them available. They're based on the WorldWorks Mayhem Streets of Legends tiles. That being said, I am going to shoot them an email regarding distribution somehow...
Adeptus Monk-anicus
Direct Fire! My Epic Blog
My Trade/Sale List
Last edited by berzerkmonkey on Tue Jun 05, 2012 4:28 pm, edited 2 times in total.
 Post subject: Re: Workin' on some roads
PostPosted: Fri Jun 01, 2012 7:55 am
Aww...I was hoping this was like other projects of your's. :'(
Well best of luck and I hope to see a finished project either way!
My NetEA Lists:
Fir Iolarion Titan Clan List
Dark Angels List
Always looking to Trade!
Angel's Trade Thread
PostPosted: Fri Jun 01, 2012 8:38 am
berzerkmonkey wrote:
Before anyone asks,............
Can you make them available for perusal once finished? :tut
PostPosted: Fri Jun 01, 2012 11:28 am
Originally, that was my plan, but, like I said, cost is a severely limiting factor. It is something that is still on the table - I just have to figure out a way to do quality parts inexpensively.
Adeptus Monk-anicus
My Trade/Sale List
 Post subject: Re: Workin' on some roads - now with new design! Input wante
PostPosted: Tue Jun 05, 2012 4:25 pm
OK, so after thinking about it, I figured "Why make these things and not be able to share them?" Therefore, I sat down and reworked the entire design and came up with the following:
The size is the same, but the design is 100% my own, so I can put them up for everyone to use and there are no nagging "You stole our IP" issues.
Here's the plan:
Tiles are 3x3 inches. Why 3x3 you ask? Here's why: First off, it's pretty darn close to the original FW road designs. Secondly, after playing around with the numbers, based on a 4x6 foot table, it's easiest to scale up from a three-inch tile. Your "city blocks" can be 3x3, 6x6, 9x9, 12x12 and you can still use the 3x3 road tiles.
I'll also make available plain "concrete" pads that you can use as "city blocks" to set your buildings on in order to give some sort of unifying feel. (I'll post an image later showing what I'm referring to.)
What I'll do is provide one sheet of each type of section, so it's up to you to figure out how many to print based on your city planning.
I am also going to be making a set with foldable flaps, in case you want to mount your sections on card or thin foamcore. This will eliminate the effect of the edges of the mounting material being visible. Conversely, if you want to plan your city and adhere your street tiles directly to a larger surface, like a 2x3 foot foamcore sheet, you can do that too.
Anyway, I'll post more as I have it - any comments, critiques, questions?
Adeptus Monk-anicus
My Trade/Sale List
 Post subject: Re: Workin' on some roads - now with new design! Input reque
PostPosted: Tue Jun 05, 2012 4:45 pm
Looking good.
Could you curve off the right angle on the 90° bend a bit?
PostPosted: Tue Jun 05, 2012 5:06 pm
I'll see what I can do. I'm doing this in Photoshop, and Photoshop is awful with curves. They can be done, but it is a real pain in the butt.
EDIT: Scratch that - working on it now.
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Tue Jun 05, 2012 5:24 pm
Build the basic structure in illustrator and then import it to photoshop as a smart object to finish working on it. It should make the paths much less of a hassle than trying to do it in photoshop.
-Vaaish
PostPosted: Tue Jun 05, 2012 5:25 pm
*flails ineffectually at the warp tool and then retreats back into the safe world of vectors*
PostPosted: Tue Jun 05, 2012 6:00 pm
My initial goal was to avoid working in Illustrator, but it looks like I'll probably wind up doing that anyway since Apoc likes his roads like his ladies - with curves... ;)
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Tue Jun 05, 2012 6:14 pm
In 1/300 scale? :eh
PostPosted: Tue Jun 05, 2012 6:34 pm
In 1/300 scale?
See, i pretend i have an army case, but it's actually a vast prison complex of foam padded cells that i use to muffle the cries for help from all those miniaturised women.
On a lighter note, what about grabbing some big real world texture of asphalt/concrete and dropping those in?
PostPosted: Tue Jun 05, 2012 6:37 pm
I like these, but agree that curves are needed.
PostPosted: Tue Jun 05, 2012 6:39 pm
Actually, I am using real world concrete texture. I tried real asphalt, but I wasn't able to find anything that scaled well. I'm going to keep looking though.
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Tue Jun 05, 2012 6:46 pm
Could always plunder some textures from a computer game, legal problems as well but they'd scale and tile well and probably print ok.
Users browsing this forum: No registered users and 76 guests
