I am thinkng of using the model below as a centre piece for a city in various states of destruction, it is N scale which i believe is true 10mm scale and wont look bad against epic minis
After a long discussion with the missus about little polystyrene bits floating around the house we have ahem "agreed" to this being the final table I will put together so I need to be happy with it ( not sure this ill be true tho).
on the upside she has agreed not to look disaprovingly at me or make mention of the cost
so basically I have a freehand to do what I want without a budget (well what I can afford is a limit but she wont say anything)
Im currently looking for some ideas on the following
1) ground type - I would like to get away from my usual green boards and trees, currently thinking desert/messa or volcanic terrain.
2) using rocky spires and crystal formations instead of forests
3) 6'x4' board made up of 12 x 2'x1' boards with terrain fixed allowing for various setups.
I am also thinking that with these smaller modules I can approach each as a 40k board on a smaller scale allowing for more detailed work.
one of the reasons for this is that I dont fancy doing an entire city board but would like some sections that can represent the edge of a city while allowing outposts to be placed further aay
Any ideas you guys have would be well appreciated and I will try to update my progress for those that are interested
Thanks
