Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
Make a Gothic building with battle damage Tutorial
 Post subject: Make a Gothic building with battle damage Tutorial
PostPosted: Wed Aug 10, 2011 3:15 am
I have been ask several times by friends to do a epic building Tutorial.
So here goes my first attempt at it!
First lets start with the building in question.
PS. I will do a paint up in a later topic, will try to link it to this one later.
I will have to do this in several post because I Cannot add another attachment, 3 is the maximum.
if any one knows how to post more at one time, I would love to know.
File comment: The building I am making.
File comment: Just some things you will need to make this building.
File comment: This is the scale I use for epic building, for I beams corners of building and pipes.
"In the desert, the line between life and death is sharp and quick." Zensunni fire poetry from Arrakis
my gaming blog https://vongutenboom.wordpress.com/
vongutenboomgames instagram
 Post subject: Re: Make a Gothic building with battle damage Tutorial
PostPosted: Wed Aug 10, 2011 3:22 am
will be keeping an eye on this
as to how to post pictures. what i do, is go to www.photobucket.com and create an account, at which point you can upload pics to there, and via the [img] tags on this forum, show the pictures here at full size as many per page as you feel like
PostPosted: Wed Aug 10, 2011 3:23 am
Mate that is awesome. I'm stealing your idea :D So simple! Now I know what to do with all my extra ruins.
Thanks for posting this idea.
PostPosted: Wed Aug 10, 2011 3:54 am
Second part of the Tutorial.
First you need the second Ed buildings from the Epic 40k starter set.
You will need the roof tops of the first epic starter set. if you do not have them ebay is a good bet.
First you need to get rid of the pegs on the under side of the roof.
next you have to measure out each part of how much building you need for each section,
and mark with pen or knife.
Cut the base with clippers were you have marked your measurements.
File comment: You will need the roof tops of the first epic box game. if you do not have them ebay is a good bet.
File comment: the before and after roofs.
File comment: cut the base with clippers were you have marked your measurements
PostPosted: Wed Aug 10, 2011 3:57 am
No problem I love to make Epic terrain and I plan to document every new one here on Tac.Com.
Thanks
PostPosted: Wed Aug 10, 2011 4:00 am
@ Jaggedtoothgrin
Thanks for the info on the Photobucket idea that might help for the next project!
PostPosted: Wed Aug 10, 2011 4:13 am
Third part of the Tutorial.
once you have cut the base it is easier to score the building for cutting.
cut off tabs.
To make new building corners, use plasticard tubes that are solid in the middle or if you
have the flat spru as seen in the second photo from the top, that is a cheaper method and still looks good.
Also when you go back and cut nicks in it for ware and tear it looks even better.
File comment: once you have cut the base it is easier to score the building for cutting.
File comment: cut off tabs.
"we don't need no stinking tabs!" =^,^=
File comment: To make new building corners, use plasticard tubes that are solid in the middle.
PostPosted: Wed Aug 10, 2011 5:16 am
Forth part of the Tutorial
Attach the plasticard to the peace you have cut out.
Start attaching building corners that you have cut out. to form the walls, "super glue together."
(you do know how to use super glue ? right ... don't you?)( you should know this! :P)
Use super glue to put the roof on your walls that you have made.
File comment: attach the plasticard to the peace you have cut out.
File comment: start attaching building corners that you have cut out. to form the walls, super glue together.
File comment: use super glue to put the roof on your walls
PostPosted: Wed Aug 10, 2011 5:49 am
Fifth part and final part of the Make a Gothic building with battle damage Tutorial.
You can add plastic card if you like, so that the building looks like there are floors through the damaged building.
the middle of the inter wall has a lip that runs the length of the walls! this is were you can attach plastic card for
the floor.
If you use the ruin building walls so that there are some broken areas, you can cut in to the roof to add to the damage.
I like to use a rounded edge blade to cut out this bit, its easier to control. you can see the blade in the second photo of the first part of the Tutorial.
Finally done building, and ready to be painted! But that will be anther day and anther post!
I love to make terrain for my battle field. and I will be doing a lot more of these Tutorials so keep your
eye out for them.
Thank you for reading this I hope it is of use to you,
File comment: You can add plastic card if you like, so that the building looks like there are floors through the damaged building.
File comment: If you use the ruin building walls so that there are some broken areas, you can cut in to the roof to add to the damage.
File comment: Finally done building, and ready to be painted! But that will be anther day and anther post!
PostPosted: Wed Aug 10, 2011 9:50 am
Brilliant idea! Now just how to get those pesky ruins ;)
I have actually done something similar, making factory buildings for an industrial complex. Will post pics soon when Summer vacation is over :)
PostPosted: Wed Aug 10, 2011 5:28 pm
Oh yes good Point Oberst Lynild
I got the ruin building spru in the 2nd Ed. of Epic 40k game.
and the Roof tops from the Space Marine game (which is really just Epic 1st Ed.,
see photos...)
but these are still available on ebay , from time to time.
File comment: Epic 40k is were the Ruins come from.
File comment: The Space Marine game is were the roofs come from.
PostPosted: Wed Aug 10, 2011 8:02 pm
I think that was sarcasm, most people know where the ruins are from there just a pain in the arse to get a hold of them at a decent price, lol. ;)
Btw, if you PM Lord Aaron he might be able to help you with ruins.
See ---> http://www.tacticalwargames.net/taccmd/viewtopic.php?t=18981
Awesome job Selim Wormrider, both with the terrain and the tutorial!
PostPosted: Wed Aug 10, 2011 8:35 pm
True, I had thought it was meant as sarcasm!
but say you are new to Epic 40k universe and you have not grown up playing all the
Epic Space Marine - Epic 40k, and Adeptus Titanicus - games,
and just started with Epic Armageddon. You might what to know!
Or maybe I am taking this whole making a Tutorial thing to serious ! ;)
PostPosted: Thu Aug 11, 2011 1:48 am
Less chit-chat, more cutting and gluing ;D
PostPosted: Thu Aug 11, 2011 2:01 am
Selim,
Yeah sarcasm is an old buddy of me, can't seem to shake him ::)
I have a pile of the old roofs (and the newer ones), but we've used up all of our ruins at the club. Luckily enough, someone had the foresight to dump a set in rubber, so I just have to get off my arse and order some resin (which is expensive enough on its own).
And yeah, it's bordering illegal, but stuff's oop and it's for private use only, blablabla ;D
