Summoning Core
 Post subject: Summoning Core
PostPosted: Mon Mar 07, 2011 9:18 pm
I wanted to create some terrain pieces that work with my Epic necron army. Dawn Of War had some cool Necron structures that looked pretty easy to scratch-build, like this Summoning Core.
This is the method I came up with (it took a couple of attempts). First, the ingredients:
  1. 3mm plasticard
  2. 1mm or 0.5mm plasticard
  3. Liquid poly cement
  4. 5mm drill
  5. Razor saw
  6. Clothes pegs
The first thing to do is cut out two 15mm x 24mm rectangles from the 3mm plasticard. I decided to score on the design while they were still attached to the main sheet. You’ll almost certainly want to use a razor saw to do this.
Then cut a 12mm x 22mm piece of 1mm or 0.5mm plasticard. This is a spacer that goes between the other two pieces, making a sort of sandwich. It’s smaller than the other two pieces so that a gap shows. Glue them all together with liquid poly and use some clothes pegs to clamp them together.
Once the glue has set, use a 5mm drill to drill a hole through the middle. The hole should be 75mm from the top, and on the centre line. I drilled a pilot hole with a pin vise to make the drilling a bit easier.
Once you’ve drilled the hole, take your razor saw and cut grooves over where you’ve previous scored. If your razor saw is a thin one like mine, you may need to make two parallel cuts and carve out between them. A round file can be used to chamfer the edges of the grooves.
Mount on a 24mm base and you’re done! Here’s the finished piece.
Here’s another terrain piece I made. You can get quite nice effects with just a few bits of plastic.
 Post subject: Re: Summoning Core
PostPosted: Mon Mar 07, 2011 9:34 pm
That is awesome.
PostPosted: Mon Mar 07, 2011 9:49 pm
Just doing another pair of cores, coming together much better the second time around!
PostPosted: Mon Mar 07, 2011 10:58 pm
Moar.
PostPosted: Tue Mar 08, 2011 12:30 am
Loveley!
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Tue Mar 08, 2011 6:00 pm
Experimental NetEpic rules here.
PostPosted: Mon Mar 14, 2011 6:35 am
Cool Beans Jodrell!
PostPosted: Fri Mar 18, 2011 3:43 pm
Painted.
PostPosted: Fri Mar 18, 2011 4:27 pm
Snazzy!
PostPosted: Fri Mar 18, 2011 4:28 pm
Very cool looking. A bit off topic but what do these things do in the game?
PostPosted: Fri Mar 18, 2011 4:35 pm
The experimental rules given seem to be combination Portal and ResOrb.
PostPosted: Fri Mar 18, 2011 4:39 pm
Not sure what it does in DoW but Summoning Core seems to imply a reinforcement doohickey of sorts. Maybe replace objectives with this for 50 points and allow all teleports to reroll ones if one unit is within 15cm of it?
PostPosted: Fri Mar 18, 2011 4:48 pm
I imagined them as working a bit like a drop pod, except instead of carrying a fixed number of troops, necron units could use them as portals (note this only works in stephane's codex, zap123's works differently).
PostPosted: Mon Mar 21, 2011 8:37 am
They are a upgrade building of sorts. Allow the Monolith to build expanded troops types. But with other races it would be there basic/main troop building. Game equivalent would be a SM Chapel Barracks, IG Infantry Command, Eldar Aspect Portal etc.
PostPosted: Mon Mar 21, 2011 12:23 pm
Whatever they do in DoW they could easily be used as cool looking Necron objectives, if nothing else.
