Large styrene sheets
 Post subject: Large styrene sheets
PostPosted: Fri Jun 26, 2009 6:23 pm
Hi all,
I'm looking to get hold of some large (at least 600mm x 600mm, preferably 1000mm x 1000mm or larger) sheets of 1mm thickness styrene. It's for a modular city system I'm planning on putting together (I'm going to create a simple grid system and then create "tiles" with various terrain pieces that slot into holes in the base sheet). I've tried a couple of different sources without any luck. Can anyone recommend someone based in (or who will ship to) the UK?
Thanks!
NetEpic Necron Army Book
[ jodrell.org | @j_plays_games | @jodrellplaysgames ]
PostPosted: Fri Jun 26, 2009 6:50 pm
There are tons of plastic suppliers in the Uk dude, no need to order from abroad.
These guys: http://www.stephen-webster.co.uk/amari/stephen-webster/ are local to me and seem to have what you want.
Try industry listings like these too: http://chemicals.kellysearch.co.uk/supplie....55 - there might be a more local supplier there.
Hope that helps,
Gabe
www.darkrealmminiatures.com
PostPosted: Fri Jun 26, 2009 8:05 pm
Ive brought 1mm (1372mm x 660mm) sheet from MUTR (Middlesex uni teaching resources)’s public web store before, they don’t have much of a range thickness though (ive always been ordering other things from them as well).
http://www.mutr.co.uk/product_info.php?products_id=514
PostPosted: Fri Jun 26, 2009 8:53 pm
Theres a handy model supply shop in North London (I get all my 6mm girders from there). Where do you live?
PostPosted: Fri Jun 26, 2009 9:25 pm
4d models at Tower Bridge do a wide selection of large plasticard sheets.
PostPosted: Fri Jun 26, 2009 10:57 pm
Hey dude,
DOW make a high density blue foam called STMG, that comes in sheets 600mm wide, 2600mm long and is 30mm thick. This is what I use to make tiles with. Just do a local search on insulation providers and you will find one that works with DOW Foam. If you are lucky the will cut the sheet to length for you as well.
Aaron
PostPosted: Sun Jun 28, 2009 12:10 pm
do you men styrofoam because the best way to get those cheap an in big boards you just have to go to your home improvment store an get some isolation styrofoam sheats
sun tsu the art of war
PostPosted: Wed Jul 08, 2009 4:25 pm
I popped down there in my lunchbreak (my office is on Moorgate) and bought five 620mmx680mm sheets for £15. Result! I can see myself going there regularly. Excellent range of foam, styrene, foamcore, etched brass, trees... that place is amazing.
PostPosted: Wed Jul 08, 2009 10:55 pm
Yeah, they're my number one resource for any modelling supplies!
