"Zombie Robot"  Structures - Otterman Cast'm ...
 Post subject: "Zombie Robot"  Structures - Otterman Cast'm ...
PostPosted: Sun Aug 17, 2008 6:02 am
[CODE] :alien:  ... the little crystals I got at a craft store and the clear plastic rod(to make things look "floaty")at the hobby shop ...
PostPosted: Sun Aug 17, 2008 6:04 am
[CODE]  ... Looted Ork Rhino for scale ... this greenskin really made a wrong turn ... :alien:
PostPosted: Sun Aug 17, 2008 6:08 am
[CODE] The base of the Summoming Core is one I cast myself ... I tried to make the soil under the hovering Core look like it is glowing beneath the ground ... some weird effect caused by the Core (?) ... :alien:
PostPosted: Sun Aug 17, 2008 6:14 am
[CODE]
PostPosted: Sun Aug 17, 2008 6:15 am
[CODE]   :alien:  Decals are Necron 40K ... cut to size ... :alien:
PostPosted: Sun Aug 17, 2008 7:33 am
Very cool mate.
I always like seeing your stuff, very inspirational.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Sun Aug 17, 2008 8:15 am
ooooh, very spiffy :D
Ideas are like soda cans, recycling sucks
If you talk to God you're religious. If God talks to you, you're psychotic
My Epic Blog
PostPosted: Sun Aug 17, 2008 9:43 am
Grand :) :) :)
Nice design, and your green edging is perfect L-4.  8v)
Back from oblivion (again)?
PostPosted: Sun Aug 17, 2008 4:31 pm
Thanks Boyz ! O-man did a great design job on these. The Control Point[CP] (with "floaty" top) gave me a lot of options. The Basic CP is next to the S/Core. The square base, column, top floaty square and 4 little Easter Island [EI]looking bitz that are on all 4 sides. I cut a piece of plastic sheet to glue on the square base with little pieces sticking out to glue the "EI" bitz on.  The other 2, I simply glued the EI Bitz on the floating square top. One with the bitz facing in ... the other facing out. Then attached the crystals using white glue. I used white glue on all the rods and crystals as super glues would cause them to "fog up" ... :alien:  And green edges are GW Scorpion Green. On black it's so bright it looks like its "glowing" ...  :alien:
PostPosted: Sun Aug 17, 2008 4:50 pm
Me wantz!!!
PostPosted: Sun Aug 17, 2008 6:59 pm
Oh, yeah, Kool-Aid man!
Moscovian gets a free set for his work on Raiders.
The Summoning Core is a pain in the ass to get aligned right. I may make a solid version for fumble-fingers like myself.
Fair disclosure: I was a Kool-Aid man in college.
PostPosted: Sun Aug 17, 2008 7:52 pm
Wow :)
PostPosted: Mon Aug 18, 2008 4:21 am
Yes, the Summoning Core was a bit challenging ... but fun to do ! I even have it hovering off the ground. :alien:
PostPosted: Mon Aug 18, 2008 6:27 am
A suggestion?
Make the summoning core half as thick - then use two sets with a sheet of thin clear plastic/perspex sandwiched in between.
Should be easier to line up the pieces.
PostPosted: Mon Aug 18, 2008 2:28 pm
Very nice, L4. The green edges are a really nice touch.
Users browsing this forum: No registered users and 71 guests
