Epic roads
 Post subject: Epic roads
PostPosted: Thu Jun 05, 2008 6:37 pm
I've made a few sections of road, more to come, on/off ramps, tunnel entrance, bridge sections (up and down or onto/off of a bridge). Any other suggestions for sections is helpful...
Not gonna make stuff like road blocks, tank traps etc. . . because those are seperate pieces to be placed onto the raod after it's on the board.
The titan and leman russ chassis (FW, note the sponsons) are for scale purposes.
"Stars in my pocket like grains of sand."
www.spartangames.co.uk
PostPosted: Thu Jun 05, 2008 6:48 pm
If those are motorways feeder roads and the like?
Nicely done.
PostPosted: Thu Jun 05, 2008 7:12 pm
"On/off ramps" are feeder roads/slip roads/merging roads etc . . .
PostPosted: Sun Jun 08, 2008 5:24 pm
I've begun making the bridge and tunnel sections, also very small feeder road bits, not got pics of those yet tho.
These are the first set of pieces a bit more painted:
PostPosted: Sun Jun 08, 2008 5:43 pm
cool they look good,
what kind of lengh have you made them?
PostPosted: Sun Jun 08, 2008 6:58 pm
Each road section is 177mm long, 150mm wide, 7mm thick, each lane is 19mm wide.
There are currently cut;
7 straights, 4 curves, 1 tunnel entrance, 2 bridge ramps, 2 on/off ramps (1 left, 1 right).
PostPosted: Tue Jun 10, 2008 11:55 pm
Christened my roads today, they helped a stormhammer company, plus Leman Russ upgrade and 2 Hydra move faster to kill all hopes of Pulsars Black Templars being victorious!
PostPosted: Wed Jun 11, 2008 1:47 am
yep that they did, got to have a closer look at the roadsthis evening and i got to say they are a really nice bit of work, the way they fit together is cool, i think you maybe making more than one set of these!!!!!!!!!!!!!!!!!!!!!!!!!
PostPosted: Wed Jun 11, 2008 7:21 am
I'm gonna cut loads and spray them road colour, then you can have them and damage and detail them as you like. It's painting the white stripes that gets really annoying - so you'll have to do that, everything else is quick and easy.
