Eldar Terrain
 Post subject: Eldar Terrain
PostPosted: Thu Mar 13, 2008 5:03 pm
Hey everyone,
I notice a lot of ruined and non ruined Imperium-esque buildings being used predominantly, and I was wondering if anyone knew of any cool looking Eldar themed scenery?
Or, if anyone had any suggestions of what to use. I plan on making some myself, but I've so far only come up with things like the Avatar from the Cauldron of Blood, and broken Wraithgates etc etc. Any ideas?
PostPosted: Thu Mar 13, 2008 5:13 pm
The Dawn of War computer game has some interesting Eldar scenery. You could check that out.
PostPosted: Thu Mar 13, 2008 5:27 pm
Do people consider the Eldar structures (not really buildings) in Dawn of War to be canon? I never thought they looked very good (more like halfway between eldar and imperial). Some of the structures are okay, but how many different variations of a warp gate do you need?
As for answering the OP's question, you might have some luck looking for fantasy elven terrain, then doing some minor conversion work to add some obviously eldar details.
It might be possible to find 10-15mm-scale terrain, but you would have to 'down-scale' it - adjust window and door sizes mostly.
Another way to go might be to make Exodite terrain (unless you'r gonna build an entire craftworld table). Exodite structures could look like anything, for all we know.
PostPosted: Fri Mar 14, 2008 1:09 am
  My take on some Eldar structures ... :alien:
PostPosted: Fri Mar 14, 2008 1:55 pm
What are the sides of the smaller Wraithgate made of? They look familiar, but I can't name them . . .
I think I might use the idea of statues and ruined temples. Unless, like mentioned, I go the Exodite way. Since they are all kinda "backwater" then, I really can make whatever.
I think the main problem with Eldar scenery is trying to capture the lithe,  graceful thin structures from the background on such a small scale. I'll have to see what I can come up with. Thanks for the info / help!
-J
PostPosted: Fri Mar 14, 2008 3:52 pm
The smaller Gate is made from the blades of the front of the Mega-Gargant ! :) So is the ruined gate behind the other gate.  :alien:
PostPosted: Fri Mar 14, 2008 4:29 pm
[CODE]   The Blades were cut off and replaced by WWII Dragons Teeth AT Obstacles ... then ...
PostPosted: Fri Mar 14, 2008 4:33 pm
[CODE]   Using an old Space Fleet base, the Shrine piece from a 40K Eldar Aspect box set and some more of the Mega-Gargant blades ...
PostPosted: Fri Mar 14, 2008 4:44 pm
[CODE]   A while back, in some old W/Ds they showed some terrain that looked like it had an Egyptian basis.  Note the Shrine piece - very Egyptian in design.  They also mentioned/allued to a Necron connection ...  This 15mm piece is from an OOP Gladiator Game. With  more 40K shrine pieces and Necron bitz added.  They never really took the Eldar-Necron connection very far ... but it was a cool idea, IMO ... :ghostface:
PostPosted: Fri Mar 14, 2008 4:49 pm
[CODE]  Also ... A 40K Fire Prism piece put to good Epic use ...
PostPosted: Fri Mar 14, 2008 4:53 pm
[CODE]  A WHFB Elf piece also put to good Epic use ...
PostPosted: Fri Mar 14, 2008 4:59 pm
My Webpage   I looked around my War Room and realized, I had a bit more Eldar Terrain then I thought !   So I went a little overboard !   But here's a link with more pics of my Eldar terrain ... hope it gives you(and others some ideas). :alien:
PostPosted: Fri Mar 14, 2008 5:26 pm
(semajnollissor @ Mar. 13 2008,10:27)
Probably not. Better than nothing, though.
PostPosted: Sat Mar 15, 2008 12:44 am
Lovely work L4 (as always).
Very inspirational.
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Sat Mar 15, 2008 2:49 am
Thanks Onyx !  That's why I do it, share the ideas with the crew !  :D
