Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 63, 64, 65, 66, 67, 68, 69  Next
PostPosted: Sun Aug 09, 2015 8:19 pm
And here is the Eldar styple pieces. Some better photos to follow.
Can be found on:
PostPosted: Sun Aug 09, 2015 8:30 pm
Oi, mate! I've been looking for Ork buildings like that for a little while now - they look fab!
Price list pls. <3
PostPosted: Sun Aug 09, 2015 9:03 pm
Cool stuff I like.
PostPosted: Sun Aug 09, 2015 10:00 pm
I aldo would like a price list! Time to order some Ork dwellings!
PostPosted: Sun Aug 09, 2015 10:06 pm
Cheers chaps! :)
Right, prices will be -
a) Single story building - £1.25
b) Double story building - £1.95
c) Double Story with 1x 'L' shape extension - £2.70
d) Extra 'L' shape extension - £0.75
e) Building with roller shutter - £2.75
f) Building (e) above without roller shutter - £2.75
Can be found on:
PostPosted: Sun Aug 09, 2015 11:15 pm
Looking very good!
PostPosted: Mon Aug 10, 2015 3:14 pm
Looks good !
PostPosted: Thu Nov 19, 2015 6:50 pm
Just thought I'd pop into this thread again to see if you were experimenting with buildings. :-X
PostPosted: Fri Nov 20, 2015 12:23 am
Hi,
Yes, I'm back designing and cutting :)
At the moment I'm busy doing acrylic bases which will be available through Vanguard Miniatures sometime soon.
I'll be picking up doing the buildings soon. A factory building will be next up I think.
Can be found on:
PostPosted: Fri Nov 20, 2015 7:08 am
Thanks for the heads up +psypher+
I will be stocking these new acrylic bases as soon as they can be cut, initially a strip base 40mm x 12mm will be available similar to the old GW epic strip bases. If these are popular then I will add different shapes and sizes as time goes on.
PostPosted: Mon Nov 23, 2015 8:11 pm
So here are a photo of a couple of bases that dropped out of the cutter the other week :)
There are more layouts for the holes other than the ones shown. They are 2 part acrylic at 0.8mm per piece, total thickness of assembled base is 1.6mm.
For all your miniature base needs, check out Vanguard Miniatures in the coming weeks ;)
Paul
Can be found on:
PostPosted: Mon Nov 23, 2015 8:26 pm
Ooh, lovely strip bases. I'd pay extra for a chamfer around the top edge.
PostPosted: Mon Nov 23, 2015 8:31 pm
Unfortunately the cutter won't do a chamfer edge. Although once assembled, run each side of the top of the base at desired angle along some fine sand paper and Bobs your uncle, although a little messy and time consuming....
Can be found on:
PostPosted: Mon Nov 23, 2015 10:09 pm
How well does the material lend itself to sanding? Transparent plastics have given me more trouble than opaque ones in the past.
PostPosted: Tue Nov 24, 2015 4:57 am
Nice!
