Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 57, 58, 59, 60, 61, 62, 63 ... 69  Next
PostPosted: Fri Mar 20, 2015 11:05 pm
Reedar wrote:
Colour me interested too.....
Can be found on:
PostPosted: Fri Mar 20, 2015 11:10 pm
primarch wrote:
I had no idea you could do this. I commissioned some custom bases not too long ago. I wish you would have shown these earlier.
Neither did I until I was messing around waiting for one of Moredakka's sheets to be cut :)
Nevermind mate, these things happen. I hope to catch you over the weekend by the way, possibly later Sunday?
Paul
Can be found on:
PostPosted: Fri Mar 20, 2015 11:12 pm
Alf O'Mega wrote:
Definitely interested in these, the holes are burnt in right? So they're one piece?
They are indeed mate. The next batch will be 1/10th of a millimeter deeper. These were just a prototype/mess around to see if they work :)
Can be found on:
PostPosted: Fri Mar 20, 2015 11:27 pm
So heres a figure in the bases. As I mentioned earlier, these were the prototypes. The hole recesses will be a 1/10th of a mm deeper and I will probably resize the brick/block work to be a little smaller.
I can also do custom etched designs, number of holes can be reduced, different shaped, Hex, Diamond...options go on and on...
...and I'll be doing some of these with rubble etc in resin. Also larger bases are on the cards too :)
Can be found on:
PostPosted: Fri Mar 20, 2015 11:29 pm
And the first model of a new, totally none gothic range I'll be doing....
Can be found on:
PostPosted: Fri Mar 20, 2015 11:31 pm
And then there is a set of air-con pipe/vents that fit all of the laser cut and resin building roof pieces :)
Can be found on:
PostPosted: Fri Mar 20, 2015 11:33 pm
....And now I'm going to go and pour myself a beer! :)
Can be found on:
PostPosted: Fri Mar 20, 2015 11:47 pm
You deserve it!
PostPosted: Fri Mar 20, 2015 11:55 pm
primarch wrote:
You deserve it!
Still can't go to bed yet, I think between Moredakka's project and the ideas stuck in my head, we're going to wear out the cutter in no time! I feel sorry for the postman / woman who has to carry this parcel!
Can be found on:
PostPosted: Fri Mar 20, 2015 11:56 pm
Wonderful stuff mate looking good, oh and make that several beers it must be thirsty work with all those burning wood fumes around.
PostPosted: Sat Mar 21, 2015 12:31 am
Good work so far!
PostPosted: Sat Mar 21, 2015 8:36 am
Fantastic!!
PostPosted: Sat Mar 21, 2015 10:40 am
Is it possible with those flagstone bases to make bases that have the flagstone footpath on one side, and it moves to a road on the other. So you'd burn down for the road, and then burn down a little more for the space where the figure standing on the road is placed. That way the figure on the road is appropriately slightly lower than the figures on the flagstone footpath.
Does this make sense?
It's kind of like what I've done with the stompa base in the background of this picture: http://imgur.com/ABdiU4p
I want something like this for most of one of my armies, so I'd be interested in saving some time when I get around to that army.
PostPosted: Sat Mar 21, 2015 1:28 pm
I had a few mate. Didn't finish cutting until after 00:30 then started bagging the lot up. Lazy day today I think! :)
Can be found on:
PostPosted: Sat Mar 21, 2015 1:29 pm
Stormwind wrote:
Good work so far!
Cheers mate :)
Can be found on:
