Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 51, 52, 53, 54, 55, 56, 57 ... 69  Next
PostPosted: Thu Jan 29, 2015 12:05 am
You'd probably get 3 of the 2.5 stands into the each of the Guild Hall's corner towers and a lot more on the open section and also Precinct building. I don't really see an issue with using those ones on these buildings at all. Sadly I don't have any of those style stands to illustrate the point but perhaps psyher does...
PostPosted: Thu Jan 29, 2015 12:16 am
Bissler, I'm liking those all painted up and with the mirrored windows! Cant wait to see the Cathedral building :) Great work mate!
Can be found on:
PostPosted: Thu Jan 29, 2015 12:21 am
primarch wrote:
Question for psypher.
While the buildings are made to accommodate the original 20mm square bases as in can they be made slightly larger to accommodate 25mm bases?
A lot of my projects are going to the larger base size, is Its important to know.
Hi, Bissler beat me too it. I've done the buildings so they are approx 41mm wide so you can get 2x 20mm side by side or 1x 40mm base. So yes, they will accommodate 25mm bases, but it just means they will have to be placed staggered or in a row, one behind each other.
Hope that helps :)
PS.......they can be tweaked for Special projects :) :) :)
Can be found on:
PostPosted: Thu Jan 29, 2015 12:31 am
The Bissler wrote:
Maybe best not to build Peach Trees to scale... I was mucking around and figured out that it would be 2 metres tall! ;D
Haha...Now theres a drawing challenge!! :)
My 1st version of a Peach Trees style sits just under 500mm tall :) I've just finished (5 mins ago) the front elevation. so 2 sides and rear to go. Should be done by the end of the weekend, and cut for the following :)
Its probably going to have its own 200mm base plate on a 400x400mm tile I'm thinking...
I've just been given the use of a BIGGER cutter when its not in use, so I'm looking at doing the 400x400mm tiles as sets. Can easily knock out a 4ft x 4ft table in less than a week I'm guessing. So when I get time to finalize my layout, I'll be cutting the first 8 tiles in the next 2-3 weeks.
...I think its just the smell of laser cut wood thats got me hooked.....
Can be found on:
PostPosted: Thu Jan 29, 2015 4:53 pm
Good to know! ;) ;D
PostPosted: Sun Feb 01, 2015 9:23 pm
Tall tower - Gothic style.
PostPosted: Sun Feb 01, 2015 9:24 pm
Tall tower - office block.
PostPosted: Sun Feb 01, 2015 9:25 pm
Small tower block.
PostPosted: Sun Feb 01, 2015 9:28 pm
Cathedral
PostPosted: Sun Feb 01, 2015 9:31 pm
Terminators attend a service at the Cathedral.
PostPosted: Sun Feb 01, 2015 10:11 pm
They look great Bissler!
PostPosted: Sun Feb 01, 2015 11:29 pm
Cheers Primarch, personally I'm not sure... I wanted to change the colour scheme for the Cathedral. I don't know if I'd just have been better sticking to my tried and tested scheme. :-\
Happy with the rest of it though! :)
PostPosted: Mon Feb 02, 2015 12:08 am
Nothing wrong with tried and tested. They look good as is. :)
PostPosted: Mon Feb 02, 2015 9:02 pm
Hi Bissler, thanks for sharing photos of your painted buildings, they are looking great! Keep up the good work :)
Can be found on:
PostPosted: Mon Feb 02, 2015 9:03 pm
So here is the Final version of the Hall of Justice kit...
Can be found on:
