Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 37, 38, 39, 40, 41, 42, 43 ... 69  Next
PostPosted: Thu Aug 14, 2014 7:17 am
They look great. Had you thought about doing tiles with road terminations ? Turning circle/hammerhead/entrance to underground parking...?
PostPosted: Thu Aug 14, 2014 7:40 am
CAL001 wrote:
Mate,
Sorry if I have missed this, what are the dimensions of the tiles? What are you looking at for cost, set make up and the like.
Aaron
+psypher+ wrote:
So here are all 5 tiles cast and with ink splashed over them to pick out detail. I know they are naff photos, I'll have some better ones done in a wee while.
Hi Aaron,
Cheers mate, I was looking at £2 a tile. The dimensions are 100mm x 100mm square, 5mm thick at footway level and 3mm thick at road level.
set wise would be something like 4x straight tiles, 4x Paved, 2x 'T', 2x X-roads, 2x bends and would probably £25 for the set.
I have a few ideas for a few more tiles in the near future to compliment these. :)
Can be found on:
PostPosted: Thu Aug 14, 2014 7:42 am
primarch wrote:
Wonderful psypher!
I have not forgotten how much I want these. ;)
Cheers mate :)
Can be found on:
PostPosted: Thu Aug 14, 2014 7:47 am
Lead-Space wrote:
I want them NOW! CAL: psy mentioned that each will be around 2£
Cheers mate. They are available now :P However I'm ditching the online shop as there has been little interest through it. I'm mostly contacted via email ,pm or Facebook for orders, so wasting money every month on the web shop.
Can be found on:
so when can we start ordering :P
PostPosted: Thu Aug 14, 2014 7:48 am
Some good ideas there mate :)
Can be found on:
PostPosted: Thu Aug 14, 2014 9:43 am
Ready...Steady...Go! Go! Go! :)
Can be found on:
PostPosted: Sat Sep 27, 2014 9:14 am
Its been a while since I had any time to sit down and work on anything, what with work, injuries and family :)
So thought I'd knock up a few pieces I've had drawings sitting around for a while.
These are completely different from rest of stuff I've done - no Gothic Arches or buttresses in sight anywhere :)
There are a couple of hab buildings and a large factory/workshop all with vents and pressure doors for those nasty alien environments.
I'll be doing a series of smaller buildings to tie in with these. They are all fairly basic with etched detail, so you can customize them to your hearts delight. All are solid cast pieces, however I may do the larger pieces in kit form sometime in the future if the demand is there for them.
As usual, sorry for the rush job crappy cam phone photos and basic undercoat paint job :)
Can be found on:
PostPosted: Sat Sep 27, 2014 9:29 am
Um functional generic designs should find a use for those let me think. :)
PostPosted: Sat Sep 27, 2014 1:51 pm
Nice! Will need some
PostPosted: Wed Oct 01, 2014 9:22 am
Funny, I also did hex pattern roof part for my own building :D
PostPosted: Fri Nov 28, 2014 6:33 pm
Well, its been a while and after quite a few requests for bits and pieces, I've now stated my own range of HDF (better than MDF :) ) multi-part kits. These kits are cut from 3mm HDF which is more sturdy than the usual 2mm stuff. They purposefully have very little detail so they can be easily customized to suit your own needs with a little plasticard or card and odds and ends from bits box.
This is the first batch of designs. There will be a ruined version of these building in January, along with another series without buttresses. I've also opted not to go down the Gothic Arch style :)
All of these kits will be (and are) compatible with the current resin pieces I have.
Dimensions are all approx. (w) x (h) x (l) and in mm.
Small tower - 50 x 50 70
Tall tower - 50 x 50 x 110
Small Admin/Hab block - 50 x 90 x 70
Large Admin/Hab block - 50 x 90 x 110
Can be found on:
PostPosted: Fri Nov 28, 2014 6:37 pm
I forgot to mention that some very large pieces have also been designed, one of which should be up on here monday/tuesday depending on the time I get to spend at the cutter.
I'll also have a few shots of these kits easily customized with bits of plasticard up next week too.
Can be found on:
PostPosted: Fri Nov 28, 2014 7:16 pm
A whole new frontier for you :) is everyone doing laser cut buildings these days or what. ;D
Very nice mate i like em! :)
PostPosted: Fri Nov 28, 2014 7:36 pm
hehehe :) aye, seems so, cheers mate :). Its like a big toy, and can make some very pretty patterns in wood and plastic!
I still like resin, but people seem to love laser cut wood. Maybe its the smell of the cut wood? :)
Can be found on:
