Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 69  Next
PostPosted: Sun Nov 17, 2013 6:43 pm
Here's another one of the pieces I've had sitting around that I never got around to finishing until now.
Diameter 40mm, Height 25mm
Can be found on:
PostPosted: Sun Nov 17, 2013 6:47 pm
And here's a quick 15min ruin using a few spare building tiles that I had lying around.
Can be found on:
PostPosted: Sun Nov 17, 2013 7:31 pm
That looks pretty dang good mate!
What have you used for texture on the base?
PostPosted: Sun Nov 17, 2013 9:09 pm
Hi Reedar, cheers mate. The base is a mixture of filler, pva, kiln dried sand and water, mixed together to form a weak paste and allowed to set a little, add another small amount of pva glue and apply to base with an old brush. Once it starts to set, it turns back to a smooth texture. At this point take your brush, dampen, and stipple again. Then allow to set. The pva keeps the base flexible so allows it to flex a little for durability for gaming. Hope this helps.
Can be found on:
PostPosted: Mon Nov 18, 2013 12:50 pm
Like these. More refinery/industrial terrain would be very useful.
Matt
PostPosted: Mon Nov 18, 2013 6:16 pm
What Mattman said. :)
PostPosted: Mon Nov 18, 2013 7:08 pm
Cheers for the info - it sounds like one of those things that's complicated the first time you do it, but easy once you've got the hang of it...?!
PostPosted: Mon Nov 18, 2013 8:56 pm
Hi Reedar, no worries. Its quite easy, just explanation is long winded. Just remember that once it starts to dry and looses texture, don't worry, just stipple again the texture you want :)
Can be found on:
PostPosted: Mon Nov 18, 2013 9:12 pm
Mattman and Bissler,
we'll have to see what's sitting on the drawing board and workbench ;)
Can be found on:
PostPosted: Mon Nov 18, 2013 11:00 pm
The latest in the Defence Fortification range.........Fortified Emplacement.
It can also be used as a base for the Missile Silo and Fuel Silo.
Can be found on:
PostPosted: Mon Nov 18, 2013 11:18 pm
That combo with the missile would make for a great deathstrike silo
PostPosted: Tue Nov 19, 2013 9:21 am
Yep, I love the missile silo combo! :o
PostPosted: Thu Nov 21, 2013 10:42 pm
I've been painting up some of your pieces so thought I'd share the results.
PostPosted: Thu Nov 21, 2013 10:44 pm
Some more pics.
PostPosted: Thu Nov 21, 2013 11:41 pm
Wow Bissler! :)
Very Cool! :)
