Post new topic Reply to topic  [ 319 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22  Next
6mm resin buildings in development
 Post subject: Re: 6mm resin buildings in development
PostPosted: Fri Jan 22, 2016 6:16 am
Another new thing in the...pipeline O0
The intention here is to be as modular as is practical. The straight and corner pieces will work on ground level and will also slot into the support columns for elevated pipe runs. There will also be a piece that converts between the two, so you can combine heights in the same run. The inspiration for the design of the columns is fairly obvious, but I think I've made an OK compromise between grimdark and more universally useful styles. You can see the pins on the end that will help each piece stay linked to its neighbor (elevated sections will probably still need glue). The straight pieces are 80mm long, and the elevated pipes sit 20mm above the surface which should provide just enough room for superheavies to fit underneath. Ultimately I'd like to produce some kind of refinery buildings that can be linked together with pipes to form a giant complex ;D
wastelandgamestudio.com
PostPosted: Fri Jan 22, 2016 11:36 am
Ah that looks fab!
PostPosted: Fri Feb 12, 2016 12:21 am
Awesome. I will definitely be in for a load of them.
Don't forget t piece's and manifolds.
PostPosted: Sun Feb 14, 2016 4:13 pm
Very nice. Simple yet very useful
PostPosted: Sat Oct 01, 2016 8:06 pm
Hey whatever happened with this one?
PostPosted: Thu Oct 06, 2016 10:20 pm
What happened is that I'm easily distracted :P
Although it might be time to revisit these - they might take a little tweaking since I would want them to be the same length as the road tiles I've done in the meantime, but that shouldn't be too difficult.
Thanks for the reminder!
PostPosted: Thu Nov 24, 2016 3:00 pm
I love tour stuff, and I'll place an order soon (even though shipping and customs kill me).
If I can suggest something I would like to see is the gothic version of tanks and pipelines (see for example kibri tra in sets 36726 and 36690) to build some plant/industrial building
PostPosted: Tue Aug 15, 2017 11:31 pm
Those pipes look great. If there was a piece where the two pipes seperated(even briefly, then returning again) it would give fantastic diversiity to a set-up built using these.
PostPosted: Wed Aug 16, 2017 8:22 am
Hmm... Road tiles ?
PostPosted: Sun Sep 10, 2017 7:19 am
Update time!
New building available: the Future Tech Corporate Lab! You can find it right here.
If you're in Europe, it will also be making its way to Vanguard very soon.
Also I've changed up the way I process orders a little bit - the TL;DR version is that I'll still be keeping stocks on hand, but if I'm out of something the store will still let you add it to your cart and I'll cast some up for your order right away. The turnaround time should still be only about 3-5 business days, faster if I have everything on hand already. If it'll take any longer, I'll send you an email and we can work it out from there.
As you might expect, I'm unable to do this with stuff I can't make in-house, like stuff with laser-cut parts. Speaking of which...
The roads set restock was delayed both by problems with the cut file and my supply of the particular kind of mat board used. Fortunately, I've managed to fix up the file and I should have a new stock of mat board shortly. My plan is to cut as many as I can right away and hopefully have a bit of a stockpile to smooth out any future delays. Watch this space.
That aside, my number-one priority now is...
The Flak Tower!
Here are some of the first casts of the center section and roof - the main body is the largest and most compex single-part mold I've done so far. It's been too long in coming, but this is hopefully the home stretch before it's finally available.
Thanks for sticking with me!
-Chris
PostPosted: Sun Sep 10, 2017 8:34 am
Cool looking forward to the flak tower.
PostPosted: Sun Sep 10, 2017 9:10 am
Flak tower looks promising!
PostPosted: Sun Sep 10, 2017 9:30 pm
Hex building! Why do all cool time saving designs happen AFTER I have made an overenginered kitbash??? Looking really cool. Octagonal even....
PostPosted: Mon Sep 11, 2017 11:03 am
I want one or three!
mattie
http://maashes.blogspot.com/
