Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
epic scale orbital defence cannon system
 Post subject: Re: epic scale orbital defence cannon system
PostPosted: Sat Jul 26, 2014 12:10 pm
Nitpick wrote:
I add +1 to the choir. To really make them sparkle, you would have to redo all scale giveaways. I'm thinking the rivets need to be replaced with small scale variants for one thing. Huge amounts of fiddly bits would probably be beneficial too...
Removing all the rivets would be a lot of work, but could be done. Personally the biggest things that makes those bastion towers stand out as not looking epic scale are the viewing slits, I'd have cut them off and filled in the holes or replaced them with something else for sure.
40k defence lasers can look a lot like giant lascannons though, so using 40k ones in epic can be appropriate rather than out of scale. As can be seen from the much larger again laser cannons on the Macragge's Honour (the Ultramarines Legion flagship in the recent HH graphic novel):
On the subject on large scale scenery I'd love to see someone having a go at making one of the eagle drop landers from the cover of the previous IG codex, it's pretty huge with hundreds coming down it's ramp at once and a nice eagle wing design. Probably more more scenario games or huge tables though as it'd cover too much of the table for a regular game.
PostPosted: Thu Jul 31, 2014 6:49 am
The artwork of this megacannons are Amazing, GlynG, are them based on 40k background or is another sci fi ambient?
here, the orbital defense cannons Painted.
Orkonia: http://goo.gl/j6Q3v
PostPosted: Thu Jul 31, 2014 9:07 am
It's official 40k and reasonably new, from a Horus Heresy graphic novel called Macragge's Honour by Dan
Abnett, about the Ultramarine Legion's flagship pursuing the Word Bearer's command ship after the atrocity at Calth.
It's pretty good and worth checking out, I tracked down a copy on the interwebs.
PostPosted: Thu Jul 31, 2014 10:59 am
That artwork has the same scale issues. Those immense guns looks like misplaced small-scale lasguns to me. I really do like the models though. They have got a nice Dune Gothic feel. Even with rather limited adaptation to 6 mm.
PostPosted: Thu Jul 31, 2014 11:20 am
I replaced the skeletons ,added 6mm entry doors and gun positions around the base.
PostPosted: Thu Jul 31, 2014 4:58 pm
Not having seen the model first hand I'd love to get some specific details about what you changed if at all possible
PostPosted: Thu Jul 31, 2014 11:30 pm
Jimmy-
1) I simply left off the plastic extended corners with the spiked top on the base.
2) I then added on the large gun unit a small turret and a vent from a beetleback warlord plus an aquilla on the gun barrel as seen on the bottom photo.
3) I covered the 4 skeletons around the large gun with a robed figure holding a sword.
4) base- I added Vulcan mega bolters on every alternate panel and the robed icons with swords or a door on alternate panels of the base.
All the non kit parts used were made from green stuff . I didn't buy anything extra.
Hope this helps.
PostPosted: Fri Aug 01, 2014 3:07 am
More cool!
PostPosted: Mon Aug 04, 2014 12:49 pm
Added to FB but here it is
https://scontent-a-ams.xx.fbcdn.net/hph ... 0977_n.jpg
"here is the picture. not really good. just to get the idea.
added AA platforms, a rocket pod on a long platform, extra guns next tu the skulls and an entrance (not visible)"
PostPosted: Mon Aug 04, 2014 6:00 pm
Man that is cool!
You should put out a tutorial on how to make one.
I want like, 20 of them. ;)
PostPosted: Mon Aug 04, 2014 7:05 pm
Plenty cool. Just about exactly the right amount of gunbarrel overkill :)
PostPosted: Tue Aug 05, 2014 11:23 am
primarch wrote:
Man that is cool!
Can do a short description, if you mean my version. With better pictures.
PostPosted: Tue Aug 05, 2014 3:00 pm
leaxe wrote:
primarch wrote:
Man that is cool!
That would be great!
Mainly what parts did you use and how it was put together. It's been a while since a terrain piece provoke such interest in me. ;D
PostPosted: Fri Aug 08, 2014 9:46 am
Here is a short photo series of what I added to mine. Simple as a stick.
http://bit.ly/epic-orbital-gun
PostPosted: Fri Aug 08, 2014 9:53 am
Mind making it public?
Let there be code.
