Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3, 4  Next
Modular City Boards
 Post subject: Modular City Boards
PostPosted: Mon Jul 02, 2007 1:33 pm
Looking very good so far ! If i wasn't living in a flat i'd work on something like this too :D
PostPosted: Mon Jul 02, 2007 3:29 pm
This is going to be awesome!
PostPosted: Wed Jul 11, 2007 2:39 am
Will this be setup at your Wednesday night venue?  As soon as I'm finished my course I'll head on out for a gander!
Fire bad, tree pretty - Buffy
PostPosted: Wed Jul 11, 2007 10:51 pm
Looks Really Cool ! Should be fun, "Trash'n Da Burg" ! :D  Nice concept and work !
PostPosted: Sat Jul 28, 2007 6:44 pm
its not a probleme the good thing about moduler design is it can be stored under a bead og some other place i live in a flat and i have a modulere disign consept i am working on i will host some pictures on my home page whene i get some pictures of it
sun tsu the art of war
PostPosted: Sun Feb 10, 2008 7:47 pm
Ok, so with not to long to go in the sandpit I thought I would give this a bump and remind everyone of what I have left behind and the enormous amount of work I have ahead of me when I get back. So I will be a busy boy on return to OZ and I hope to give you some updated pics of this and the other pieces that will be making up the finished table.
Aaron
PostPosted: Mon Feb 11, 2008 12:28 am
Really looking forward to seeing this take shape mate.
Very inspiring!
Just call me Steve.
NetEA Rules Chair
NetEA FAQ
Some of my Armies.
My Hobby site.
PostPosted: Mon Feb 11, 2008 2:39 am
Looking forward to seeing more work on this job that's for sure!! :)
PostPosted: Mon Feb 11, 2008 7:04 am
Stuff does look promising !  I noticed your Aussie Camo kit in the background of one of the pics ... Cool Too ! :D
PostPosted: Wed Feb 27, 2008 3:44 pm
Can you give a brief (or longer if you feel up to it) description on how you achieved the colouring on your bone/sandy buildings?
Looks fantastic.
D.
Epic:Armageddon... Like Apocalypse but for grown-ups.
[b]Bearded Dice[/b]: [url]http://bearded-dice.co.uk[/url]
PostPosted: Wed Feb 27, 2008 5:05 pm
the pictures of my take on modular city can be found here but i went haywire and design it to be a full modular landscape and there is around 50 pisses of landscape i haven't foto'et and uploaded right now i am working on a hoover dame type dame structure and a harbour and there is a marsh segment on the drawing board
PostPosted: Wed Feb 27, 2008 5:29 pm
Your city looks great, alot like the one I've always wanted to do. I would throw out a few suggestions, though.
First, make a few city blocks (I'd say 4 or 6) that are trapezoidal instead of rectangular. If everything is laid out in even blocks, it looks fake. Adding a few "diagonal" streets does alot to make it look like a real city. Along the same lines, when you play with the city, don't align the street parallel to the board edge, that helps break up lines of fire and makes it look more dynamic.
Second, make some "compound" buildings. Stack a couple of building on top of each other. Attach the side of one building to the side of another (putty it up so it looks good). I've never seen a city where all building were the same size and shape.
Finally, make a few "outlying" blocks of smaller buildings - single story, smaller in length and width and crammed together.
PostPosted: Wed Feb 27, 2008 5:42 pm
interestingly enough a have seen many city look like mine it a way of city planing from early 19th century city planing you can see it defused by time in Paris and other fortified cites i Europe before the wehrmacht came to sabastopol it looked exactly like my city more unknown is Frederecia in Denmark but it is the most extreme case of a planed fortified city i Europe because its build from scratch in the 1830's you will see this structure taking shape when a city is scratched  build for defence and riot control
PostPosted: Wed Feb 27, 2008 6:10 pm
(daemonkin @ Feb. 28 2008,00:44)
Looks fantastic.
D.
Ok, it was a while ago when I did this so you will have to forgive me if this isnt quite it. An undercoat of chaos black from a spraycan is the starting point once you have cleaned of any excess resin. Give the piece a once over with warm water and a littlely abbrasive detergent and an electric toothbrush to remove any of the stuff left over from casting.
So here goes, firstly I used scorched earth in a kind of drybrush technique that a mate taught me. You take a piece of polished surface tile and put a little paint on it. You then work your brush back and forth through the paint for a few minutes, it will become quite sticky to touch, at thi point work the paint over the building in a drybrushing technique.
Repeat this process with successive layers of bubonic brown to lightne the coulor scheme. Once this has dried and that will be reasonably quick as the paint is about half dry by the time you apply it. Hit it with bleached bone and watch it transfor to a sandstone effect.
The next thing we did was to give it a very light wash of black ink and water to add the detail back to cracks and the like. From here the intent is to the go back and revisit the windos and do some stainedglass work using colours and inks and to paint the doors. The roof will be finished with a tar effect once I get around to it.
Anyway I hope that helps and I hope I have remembered everything that we did.
Aaron
PostPosted: Wed Feb 27, 2008 6:40 pm
Ok,
So the general concept for the city was a defended city on a wealthy Imperial world with ties to Space Marine Chapters in close proximity to it. So I have a fairly simple layout to wok with.
Boards
The boards are high density insulation foam, it is great stuff, you can cut a shaving off it less than a mil in thickness. It is easy to cut and to carve to make hills and the like. Each hex as such is 500mm x 500mm. I have 40 all up with 20 dedicated to the city and 20 for general terrain boards. The city boards have the road sections attached to them.
My reasoning for using a simple design and not adding curves of angled streets is it allows me to move the city boards into different shapes. The city as designed is 5 hex wide and 4 deep. this can be changed to ten wide and two deep depending on which table edge I choose to place it on. Or I can shrten the width and extend it further out.
Modular Terrain
I have varying sizes in 3mm MDF that fit between the street sections. They vary from 275mm x 200mm to 100mm x 100mm. No two blocks are the same, and it is my intent to paint in different styles to further emphasis and add character to the city. I have also themed area with differing terrain. There are industrila structures, such as the tank factory and mechanicum chemical storeage facility. I have two different styles of landing pads to represent a civil and military transport hubs. I have a few differnet styles of buildings, the FW one and some that have been made from recreated Epic ruined building sprues and the mad into various sizes.
Defences
The city has a wall section that is also on 3mm MDF. It can be removed and replaced with defences from the FW range also mounted on 3mm MDF. Alternatively the FW defences can be placed outside the city walls and used in a siege scenario. I am also working on some trench ideas to be used as well, more on that in another thread once I have worked my mojo on them.
Ruins
I have also created two layers of ruined cityscape to replace the good sections for use with campaigns or general games. I have also kept additional wall sections so I can do some breached wall sections to give it that bombed out feel.
Terrain
I have a multitude of terrain to use on the remaining boards. I have several types of hills from GW, each one is unique in what has been done to it to give differing effects. I also have some sections of resin produced by a friend that can be rearranged in various styles that are covered in trees that will represent forrest sections. I also have an assortment of rock formations, swamp and chemical bogs on the painting schedule.
To other things I have picked up some very cool planetary defences which can be seen in the Cool Stuff thread in Terrain. In addition to this I also have my Airbase project which will work in conjunction with this.
Table
Well the table I am constructing consist of two halves which are 2.5m wide by 2m long. This alows me to play games on eith 20 or 40 hexes. Thus giving me the diversity to arrange the city as I see fit. Each half has a fixed boarder around three sides to hold the foam hexes in place. The fourth side has a removeable boarder for use when only half the table is being used. When the second half is not being used it will be hinged so that it folds under the other half. This will the rest on four sawhorses.
Well that is about it in a nutshell, I have plenty of work to do and some time hopefully up my sleeve. I have applied to take some long service leave post my trip here to the desert and I am hoping to take about three months off soldiering and get right into this project.
I hope you will enjoy it, I will post on a regular basis as it takes further shape.
Aaron
