Post new topic Reply to topic  [ 251 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 17  Next
Gregster's Lab - terrain for 6mm
 Post subject: Re: 6mm scale bunker systems Indiegogo campaign
PostPosted: Thu Oct 09, 2014 9:48 am
A sneak peek from the Sigma Star Systems walled complex kit (already mentioned in the stretch goals).
I will show you an example terrain piece using these later this weekend.
PostPosted: Thu Oct 09, 2014 1:23 pm
Looking forward to seeing what that is!
PostPosted: Thu Oct 09, 2014 1:56 pm
Hint: it is for the Greater Good...
PostPosted: Thu Oct 09, 2014 4:10 pm
I like the detail on the sculpts, and the casting looks very cleanly done. I quite like the wall pieces - waiting to see more of them.
If I have a concern, it's that the components look too small to me. If you look at the overhead shot you posted and compare the width of the corridors to the figures next to it (SM scouts, I believe?) the corridors look too narrow and the bunkers and junctions too small. I get that the height is supposed to appear lower because theoretically the complex is half-buried in the ground, but when you consider that the walls of the structure must have some thickness (especially if it's supposed to be an armoured bunker) it looks like there would barely be enough room for one person to squeeze down the corridor, and the junctions would be like standing in a phonebooth. Could you scale the pieces up a bit to make them a little more realistic?
Looking forward to seeing what else you have in store!
-Chris
wastelandgamestudio.com
PostPosted: Thu Oct 09, 2014 7:48 pm
I second the concern. A bit too small for my eye. Maybe thats only an optical illusion
PostPosted: Fri Oct 10, 2014 6:26 am
Yes, if theese where about 50% bigger i would be in for sure!
PostPosted: Fri Oct 10, 2014 8:17 am
Thanks Chris and the others for the input!
Yes, they are small. Might be even too small. Agree. Could have made them bigger. Perhaps will do it one day. Make them 50% bigger and add more detail. When I did them, I wanted to have the corridors about the size of a standard base. This is why they are too small. If the campaign goes well, we will consider that option. I also had a plan, where these corridors were sitting on top of the same design, but wider.
Here is the size:
They could be considered something like this. Covered.
http://www.ww2incolor.com/d/529433-1/Fi ... n+a+trench
The other kinD of wall:
I started doing two terrain pieces with them. Will take better photos for FB and for IndieGoGo
PostPosted: Sun Oct 12, 2014 2:59 pm
Looks good. You've got another backer. :)
PostPosted: Sun Oct 12, 2014 7:21 pm
Many thanks!!!
PostPosted: Fri Oct 17, 2014 9:03 am
New pieces that will be available later in the campaign
PostPosted: Sat Oct 18, 2014 8:27 pm
Reinforcements have arrived! A new General level funder!! With his contribution we reached 50% of the total goal!!!
Surprise coming up on Monday!
PostPosted: Sat Oct 18, 2014 8:36 pm
Here is the size:
Hey Greg,
Where did the tower come from in the second image?
Aaron
PostPosted: Sat Oct 18, 2014 9:51 pm
http://www.forgeworld.co.uk/Warhammer-4 ... TOWER.html
PostPosted: Mon Oct 20, 2014 3:34 pm
When we reached the 50% funding we started discussing the issue of the stretch goals.
We came to the conclusion, that we will abolish the stretch goals and make things available beforehand.
As we turn into the last 40 days of the campaing, the Sigma Star Systems walled compound will become available this Wednesday. (see pictures in the campaign gallery)
In the last 30 days we activate the add-on packs, so you will have access to the command bunker, the sentry tower and all the other items that were planned as stretch goals.
As a special surprise, we plan to add some more terrain as a perk. See the 3D preview of the GreyDark Industries research station..
PostPosted: Mon Oct 20, 2014 5:44 pm
Woh very nice!
