Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Gaming board textured surface advice?
 Post subject: Re: Gaming board textured surface advice?
PostPosted: Mon Dec 02, 2013 9:26 pm
Borka wrote:
+psypher+ wrote:
Also, cat litter (gravel one) mixed with pva is good. The pva soaks into it and forms an elastic film. A second diluted coat of pva once dried will strengthen it.
i used this on the 40k sized ruin bases. Even survived the moulding process without falling apart.
Interesting I will have to try this for a board I've been working on. Sounds like an easy way of doing it.
it is quite easy and cheap. Just takes a little while for the pva to dry, but worth it. Great texture for dry brushing :)
Can be found on:
 Post subject: Gaming board textured service advice: now gaming board blog!
PostPosted: Mon Dec 02, 2013 11:23 pm
Alritey, I built the board and have enough given it a folding mechanism and handles! The fact that it's all permanantely attached does mean it's a bit of a faff to set up with only one person though so might get rid of said fold...
Started texturing and colour it this evening too:
Went with a mixture of standard DIY filler mixed with PVA, water and sand along with some burnt umber acrylic paint to act as a basecoat. After this it'll be painted burnt umber, drybrushed and then given a coat of army painter dip (unless someone can reccoment a cheaper alternative?). That coupled with the PVA should make it durable enough I hope.
Anti dice rolling 'sides' will be added that will also prevent minis falling off and make sure the table doesn't get knocked.
As the weeks progress I hope to be updating this blog with the sets of scenery that I'll be creating for the board; looking forwards to gaming at home again ;D
MoK's Painting Blog
Now Showing:
