Thinking about modular buildings
 Post subject: Re: Thinking about modular buildings
PostPosted: Sat Jun 18, 2011 12:45 pm
Really cool idea here!
My only input would be to suggest 3 lengths for each such wall type:-
  • Short for towers, porches etc
  • Medium for end walls etc
  • Long for side walls.
Made in proportions of 1:2:3 this would be truely modular. The only other thought is that if you adopt this approach, then they should possibly be ~3-4cm, 6-8cm amd ~9-12cm respecively (fitting in with your original model of 9cm. The point being that you can add various panels together to make longer / larger buildings, whilst these sizes would also permit making fairly small ones as well.
The other thought is whether to mount them or not. My personal preference is that they should be mounted on bases to represent city blocks, leaving enough space around them for models to be positioned as required. Any part of the base is treated as 'built up' to represent outhouses, kiosks, gardens, fences etc. In the UK we tend to use 10cm sq bases as the basic 'block' (though some are several 'blocks') because that also coincides with the distance that can be seen through under the rules. This approach does make the smaller buildings look more appropriate
PostPosted: Sat Jun 18, 2011 2:31 pm
CAL001 wrote:
Love the work so far mate, I have always looked for variety in my buildings. Could you do some bevelling on the corners to give them more chracter? Maybe even add some detail on the bevel or add a gargoyle or something to them. Just ome thoughts to aid your thought process.
I did have a bevel on the pillars, looking like there were stacked blocks, and it looked pretty good. The problem is, on a one-sided cast, one exposed side of the pillar winds up being blank. I'm still playing around with how to fix that problem. I do agree - the pillars look like they need some detail.
I will keep your size recommendations in mind. I have already made smaller walls, I just haven't posted images yet. As for the mounting, I figure that can be up to the player. If you want to mount your buildings, feel free. If you just want to plop them down on a table, you have that option as well.
Adeptus Monk-anicus
Direct Fire! My Epic Blog
My Trade/Sale List
PostPosted: Mon Jun 20, 2011 2:01 am
you can still have detail going up the side of the mold - especially 'pop out' detail like a bevel. A one sided mold still has 5 sides.
PostPosted: Mon Jun 20, 2011 2:14 am
Yeah, but it isn't the side I'm concerned about, it is the back side of the pillar. The back of the pillar becomes the "inside" of the wall section at a 90 degree angle. If you look at my 5-story building, and look at the far right corner, the pillar you're seeing, that part is really the back of the wall piece. The sides of the pillars are no problem.
I had actually done a two-part pillar with the original design, but it is impossible to do the inside corner builds using that design.
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Mon Jun 20, 2011 2:17 am
So are the Pillars and the Walls separate or one piece?
I would think letting them be separate pieces would solve corner issues....but I'm not a CAD Wizard
PostPosted: Mon Jun 20, 2011 11:36 am
One piece. Reason being, is 1) it is easier to cast and 2) if I did separate casts of the pillars and made them 2-sided, I'd be defeating my whole purpose of one-sided molds.
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Sun Aug 21, 2011 11:44 am
Thinking of buying modular buildings from you
sun tsu the art of war
PostPosted: Sun Aug 21, 2011 12:56 pm
Are you selling these bad boys yet? :)
PostPosted: Sun Aug 21, 2011 2:04 pm
No - at the moment, they are but a fantasy. They kind of got put on hold for updates to the Lunchbox and the Evil Lawn Dart. Once I get those out of the way, I'll get back to the buildings. I promise.
Adeptus Monk-anicus
My Trade/Sale List
PostPosted: Sun Aug 21, 2011 2:06 pm
Dude,
I am with Mark (G), you need to get back to work on this, they are very cool.
Aaron
