JTG's Terrain Log
 Post subject: Re: JTG's Terrain Log
PostPosted: Sun Apr 24, 2011 1:57 pm
apparently the walls come from the sanctum imperialis, (i cut the top bits off, and made a lot of the ruined ends myself) and the comms building come from the manufactorum.
i bought the sets from an ebay bits-seller and those components only cost me about $20, although they took a bit of fiddling to get together
PostPosted: Sun Apr 24, 2011 2:20 pm
Very cool.
PostPosted: Sun Apr 24, 2011 3:52 pm
Clever!
PostPosted: Sun Apr 24, 2011 9:15 pm
Whats CoD, I know its not call of duty!
Regards epic
PostPosted: Sun Apr 24, 2011 10:17 pm
Cities of Death, the GW urban terrain range.
PostPosted: Mon Apr 25, 2011 7:31 pm
Cheers S G regards epic
PostPosted: Tue May 10, 2011 10:02 am
the march continues
still gotta do some touchups, but that can wait till later i think.
PostPosted: Tue May 10, 2011 10:19 am
Nice! I'm gonna copy the basing shamelessly, having thought long about ways to make interchangeable trees :)
PostPosted: Tue May 10, 2011 12:28 pm
Are you just using felt for the ground?
PostPosted: Tue May 10, 2011 12:40 pm
yeah, its polar fleece cut into blobs. that way i can put it onto hills or whatever fairly easily
it also has an advantage with the way i base the trees
the tree bases are made from the blister packs from my last DRM and Steel Crown orders, coated with PVA glue, paint, and sand, (took a bit of fiddling to make them colour-match with the fabric, but they're fairly close) at which point i drill holes in for the trees (bought on ebay, quite cheap, but of course, you use a buttload of them) stick the trunks down, and bend them out at an angle to hold them in place while i glue them (zip-kicker is a life-saver here) after which, i chop off the excess (sneaky tip, some of the trunks in the middle of the bases are actually just the offcuts from the bottom, with the branches from the surrounding trees covering them up a bit)
so theres a little bit of a lump on the bottom of the bases for each tree stump. the fleece lets that sink into the fabric a little without wobbling, and also gives the trees just a bit of grip onto the blobs aswell.
and of course, when you go to play, trees in the way can just be moved to another part of the forrest, or off the table, until they're not in the way anymore.
all in all i'm fairly happy with them.
