Post new topic Reply to topic  [ 1023 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 69  Next
PostPosted: Mon Aug 19, 2013 10:57 pm
A little later than expected due to rubber not being dispatched on time :{[]
here's the first of the rehashed fortification line...another plain set to follow tomorrow night.
Can be found on:
PostPosted: Mon Aug 19, 2013 10:59 pm
A few more pics...
Can be found on:
PostPosted: Mon Aug 19, 2013 11:06 pm
yes!
PostPosted: Mon Aug 19, 2013 11:26 pm
Those are looking flippin' awesome ! Just how i pictured them / what i would have made myself if i had the time !
Can't say when, but i will be ordering a set !
(Can anyone give me an idea how much i will likely need for a 3k krieg/baran army ?? )
PostPosted: Mon Aug 19, 2013 11:33 pm
DKoK=>
80cm of Trenches and Razor Wire, plus 4 Bunkers: 100points
Light Support Battery 4 Death Korps Quad Launchers or 4 Death Korps Heavy Mortars 200 Points
(Light Support Batteries may have 4 Death Korps Centaurs or 20cm of Trenches) (Free)
BSM=>
Fortified Position Up to 50cm of trenches and 50cm of razor wire, plus up to 6 Gun Emplacements +75 points
or Bunkers in any combination
They're pretty cheap so probably at least 100cm to 160cm of stuff. The DKoK come with gun emplacements as an option for arty so you'll want to factor that in as well.
PostPosted: Mon Aug 19, 2013 11:40 pm
Cheers Jimmy. Do you run either army regularly ?
ie - could you PM me any effective lists ? (will check EpicUK championship too.)
PostPosted: Tue Aug 20, 2013 1:16 pm
These are looking great! I particularly like the destroyed sections as well!
...Off to check bank balance...
PostPosted: Tue Aug 20, 2013 3:23 pm
Pricing and availability?
PostPosted: Tue Aug 20, 2013 6:26 pm
+1 :)
PostPosted: Tue Aug 20, 2013 10:27 pm
Here is a couple of photos showing the detailed sections quickly painted up.
Can be found on:
PostPosted: Tue Aug 20, 2013 10:33 pm
So, prices are as follows -
I've split these into sets.
Set 1 - Basic Defence Line (no detailing) £11.50
2x Straight sections (£2.50)
2x Gun position (£2.50)
2x Inside corner (£2.50)
2x outside corner (£2.50)
2x 45 Angle (£1.50)
Can be found on:
PostPosted: Tue Aug 20, 2013 10:37 pm
Set 2 - Damaged Basic Defence Line (no detailing) £5.75
1x Straight sections (£1.25)
1x Gun position (£1.25)
1x Inside corner (£1.25)
1x outside corner (£1.25)
1x 45 Angle (£0.75)
Can be found on:
PostPosted: Tue Aug 20, 2013 10:41 pm
Set 3 - Detailed Defence Line £13.50
2x Straight sections (£3.00)
2x Gun position (£3.00)
2x Inside corner (£3.00)
2x outside corner (£3.00)
2x 45 Angle (£1.50)
(not included in set is Straight Section with Pill Box - £3.50 for 2)
Can be found on:
PostPosted: Tue Aug 20, 2013 10:45 pm
Set 4 - Damaged Detailed Defence Line - £6.75
1x Straight sections (£1.50)
1x Gun position (£1.50)
1x Inside corner (£1.50)
1x outside corner (£1.50)
1x 45 Angle (£0.75)
Can be found on:
PostPosted: Tue Aug 20, 2013 10:46 pm
Bunker - £3.00
Can be found on:
