Orgyn Ripper Gun ...
 Post subject: Orgyn Ripper Gun ...
PostPosted: Wed Jul 11, 2007 11:14 pm
This should be a 40K topic, but frakk it !  Tell me about the Orgyn Ripper Gun ?  I've got it somewhere in my old W/Ds ... but I'll let you Boyz enlighten me ... :D
PostPosted: Wed Jul 11, 2007 11:21 pm
Extremely solid high-caliber short-ranged rapid-firing projectile weapon. Emphasis on solid construction, as it is designed to be used by enthusiastic ogryns.
Edit: I seem to recall it also has a shot-limiter (i.e. some form of semi-automatic-fire). Again for use with enthusiastic ogryns, preventing them from firing off the whole drum at once for fun.
PostPosted: Thu Jul 12, 2007 12:00 am
High ROF sub machine gun with a drum barrel, solidly built to be used as a club for when the Ogryns get in close or run out of ammo and forget to change the drum. Large calibre rounds.
Tom Webb
PostPosted: Thu Jul 12, 2007 4:04 am
That's what I thought ... Thanks BoyZ !  Good intell ! :D
PostPosted: Thu Jul 12, 2007 5:42 am
I always thought it was a full auto high capacity shotgun with a burst limiter and the ability to use as a club. Certainly in rogue trader it was auto hit at point blank and fun with following fire! The madels after the first though were awful.
PostPosted: Thu Jul 12, 2007 10:44 am
Hmm... we need a definative answer - who's got the 2nd Ed Wargear book to hand?
Tom Webb
PostPosted: Thu Jul 12, 2007 10:57 am
Here. But in german.
Here it is a full automatic machinegun with a BIG drummagazine and a burst limiter toprevent that an overenthusiastic ogryn empties the drumi n one volley.
Its i build as sturdy as it gets because ogyns have the habit to forget to shoot and instead use the gun as club.
The gunfires low velocity ammmunition at a high rate so that ogryns will inevitably hit something with it. It has a low range because ogryns have a habit for closecombat and wouldn't think about shooting something far away even if they have a weapons wich is capable of doing so.
At short range it will hit automatically.
Low Range: 0-6" hit always
High Range 6-12" to hit modifier -2
Strength 4
Damage 1
Armorpriercing W6+4
Rapid fire: 2 dice
PostPosted: Fri Jul 13, 2007 1:37 am
I have the English 2nd Ed Wargear book it is described as a drum feed fully automatic combat shotgun.  It is also described as having a burst limiter to prevent the Ogrns emptying the magazine to quickly.  It is also solidly constructed as Ogryns tend to use them as impromptu clubs.
PostPosted: Fri Jul 13, 2007 2:03 am
Yes, I now remember that it was a drum fed Shot Gun ... I only have the data in an old W/D. I got an Epic Orgyn with a barrel gone ... So I used the top of the old Epic banner pole, so it looks like the Carbine version. Now I'm getting a bunch in a trade "sans" barrel. So I'll have More of the "Kurz" version.  I'll take a pic soon.  I like the way Tom does it in the E/W fluff ...   With nomenclature, etc. ... So thanks for the all the intell Boys. :D  U R a good lot !
PostPosted: Mon Jul 16, 2007 3:56 am
[CODE]   Ogryn with Mk.2L4 Carbine ... :)
