Stats for Eldar Hemlock Wraithfight ?
 Post subject: Stats for Eldar Hemlock Wraithfight ?
PostPosted: Fri Jul 03, 2015 2:41 pm
Any Epic stats for this bad boy ?
 Post subject: Re: Stats for Eldar Hemlock Wraithfight ?
PostPosted: Fri Jul 03, 2015 2:43 pm
I may use these and Mk.IIs ...
PostPosted: Sat Jul 04, 2015 12:26 pm
Cool !!!! Thank you Sir ! :spin
PostPosted: Sat Jul 04, 2015 12:47 pm
Any reason why the nightwing stats are unsuitable?
PostPosted: Sat Jul 04, 2015 2:16 pm
Well ... I'll let you experts figure it out ... ^-^
PostPosted: Sat Jul 04, 2015 5:38 pm
PFE100 wrote:
Any reason why different stats can't be used for the Eldar Hemlock Wraithfight? It looks on paper to be a different beast from my investigation so far. :) ...
because the nightwing has established and balanced stats across multiple (all?) the other eldar lists, has 4 different models already, none of which are particularly alike, and we don't need a 4th type of eldar flyer shoehorned in when an existing unit is a perfectly acceptable proxy? ;)
the eldar already have an interceptor, air-ground attack craft and an air transport, if the 40k stats for this thing suggest it's more of a ground attack craft, then use the phoenix stats
I just don't see why we need to reinvent the wheel all the time is all..... this will almost inevitably lead to yet another spinoff list of some previously unheard of craftworld as a justification to bung another load of GW cash-cow models in..... but I've said this before many times....
PostPosted: Sat Jul 04, 2015 10:41 pm
I agree totally!
PostPosted: Sun Jul 05, 2015 12:49 pm
O.K. ... so show me what stats you think would work.
PostPosted: Mon Jul 06, 2015 12:55 pm
Sounds Good ... THanks !!!! :spin
PostPosted: Thu Jul 09, 2015 2:53 pm
NightwingHemlock AC Fighter 4+ n/a n/a
Twin Shuriken Cannons 30cm AP4+/AA5+, FxF
Bright Lances 30cm AT4+/AA5+, Lance, FxF
PostPosted: Thu Jul 09, 2015 3:12 pm
Sounds good !! Many Thanks !!!!
