Kinght Reference Doc
 Post subject: Kinght Reference Doc
PostPosted: Fri Oct 18, 2013 1:48 pm
Hi guys, Interested in trying out the Fir Iolarion list but as it's been a while I'm at a loss to find the reference sheets for the eldar knights. Can anyone post a link?
Thanks,
D.
 Post subject: Re: Kinght Reference Doc
PostPosted: Sat Oct 19, 2013 9:31 am
It's (hidden) in the main list for some reason.
viewtopic.php?f=24&t=24196
/Uven
PostPosted: Sat Oct 19, 2013 7:09 pm
Hi Uven. I downloaded both the main Eldar list and reference sheets. Neither had any reference to eldar knights. You couldn't either post the stats here or provide a link to a PDF with those stats?
Army forge is great but does not give you any stats unfortunately.
D.
PostPosted: Sun Oct 20, 2013 1:38 am
Hey Daemonkin, sorry those stats didn't make it onto the Ref sheet, TBH I hadn't realized they weren't in the ETC document.
As far as I'm aware AoC is using the collectors stats from the back of Swordwind.
Bright Stallion
AV 30cm Ar5+ CC4+ FF5+
Stallion Laser 45cm 2x MW4+
Hooves (base) EA+1
Notes: Reinforced Armor, Walker
Fire Gale
AV 15cm Ar5+ CC5+ FF4+
Fire Lance 30cm MW4+, TK(3-1 per 15cm to target)
Towering Destroyer
AV 15cm Ar5+ CC4+ FF4+
Destroyer Laser 45cm 2x AT4+
Destroyer Cannon 30cm 2x AP4+
Assault Weapons (15cm) Small Arms, EA+1 or (Base) Assault Weapons, EA+1
PostPosted: Sun Oct 20, 2013 3:59 pm
They're also in the NetEA 2012 Compendium, here:
http://www.taccmd.tacticalwargames.net/ ... 69&t=23686
in the Fir Iolarion reference sheet.
Slightly different stats than the ones above.
PostPosted: Sun Oct 20, 2013 4:18 pm
Then go with those. :)
