Saim-Hann Craftworld v4.0
 Post subject: Saim-Hann Craftworld v4.0
PostPosted: Sat Oct 13, 2012 1:57 am
Same deal. Posting up a working document.
Changes:
Engine of Vaul formation cost: One EoV for250 + 0-2 more at +200 each.
Scorpion Pulsars get three shots.
Titan Pulsars get three shots.
Cobras regain Ignore Cover.
Howling Banshees get CC, MW against INF only.
Let me know if you find any typos or errors.
Army unique units can be found on page 3 of the Reference sheets in the OP of the Biel-Tan thread.
Saim-HannList4.0.pdf [115.56 KiB]
Downloaded 592 times
 Post subject: Re: Saim-Hann Craftworld v4.0
PostPosted: Sat Oct 13, 2012 3:59 pm
Strategy rating : 3 (not 4)
Shining Spears ost limited to 1 per Wild Riders ost.
In the army list (all the lists actually), Exarchs should restricted to Aspect units. With the actual wording, I can put an Exarch characher on a Wave Serpent. Ok it won't get the extra attack.
PostPosted: Sun Oct 14, 2012 12:02 am
SR changed, thanks.
Researching the Shining Spear/Wild Rider ratio, though I believe you are correct. It does not appear in the 2012 Compendium, so I'm trying to see if there's a copy of the source list floating around. Edit - and of course I get the response as soon as I posted that. You are correct, and I'm reuploading now.
The Exarch language dates to Swordwind, but could use some tightening nonetheless. I need to figure out a way that won't end up too verbose. Perhaps including it in the notes for the Exarchs, which would then mean it would apply to Autarchs, which must replace Exarchs.
PostPosted: Sun Oct 14, 2012 10:47 am
It does appear in the Compendium 2012, just under "SAIM-HANN CRAFTWORLD WARHOSTS"
Instead of "Add up to 2 Exarch character upgrades for +25 points each", say "Add up to 2 Exarch character to an Aspect warrior unit for +25 points each".
