[Units] Experimental Shrine Specific Exarchs
 Post subject: [Units] Experimental Shrine Specific Exarchs
PostPosted: Thu Dec 22, 2011 5:29 pm
Hey all!
I thought I'd posted this a while back, but my search-fu is not finding it, so here it is for examination and discussion!
EPIC - Eldar -Exarchs.pdf [45.31 KiB]
Downloaded 524 times
 Post subject: Re: [Units] Experimental Shrine Specific Exarchs
PostPosted: Thu Dec 22, 2011 5:31 pm
Interesting, but could be a nightmare for the opponent to try to remember them all.
PostPosted: Thu Dec 22, 2011 5:32 pm
EUK did a half-way house on this IIRC, giving a couple of the worst Exarch types unique statlines, but leaving the rest generic.
PostPosted: Thu Dec 22, 2011 7:43 pm
I think this is a solid approach, but I'd make the argument that the more powerful weapon combos should be dropped down in line with the others rather than the worst brought up. The fact is, Inspiring alone is easily worth their 25 points. The weapon is just icing.
Plus, if you compare 40K squad damage with and without exarchs, there really isn't that much difference. 4 aspects and 1 Exarch don't have 50-100% more firepower than 5 aspects. I understand the Epic-scale boost probably has to be a little bit disproportionate in order to maintain the appropriate flavor, but it's still awfully high at the moment.
PostPosted: Thu Dec 22, 2011 7:57 pm
Gotta agree with Neal; Exarchs are a great buy no matter what, compounded by the ability to buy two inspiring characters, which is nearly unique.
PostPosted: Thu Dec 22, 2011 8:32 pm
I agree, I don't think "specific" Exarchs are needed at all, I'm fine with the way they are now, just I thought I'd put the idea out there for discussion's sake as it came up in another thread.
PostPosted: Fri Dec 23, 2011 12:36 pm
The shrine-specific exarches look cool, but the only one who's not a definite upgrade is the Reaper exarch (who gets better in other ways). The increased points cost might make BT hosts worse rather than better?) I like the idea of downgrading the best rather than buffing the worst.
I do think that, unless extra attacks is simply removed from all exarches, that the Avenger exarch needs buffing. His extra attack is almost totally useless, making it very tempting to add another type even to Avenger hosts.
PostPosted: Fri Dec 23, 2011 1:42 pm
That's the thing, I've found the Avenger Exarch to be very useful: in either CC or FF the stand always has an extra attack; sometimes the enemies of the Eldar do initiate assaults... *laugh*
PostPosted: Fri Dec 23, 2011 1:50 pm
while interesting, I'm not sure I like the idea of specific exarchs for the reasons given by others. However, the howling banshee exarch having Sniper made me think: has giving banshees Sniper been considered as a way of buffing them against infantry without turning them into AT monsters?
PostPosted: Fri Dec 23, 2011 3:43 pm
A 4+ reinforced save fails against Sniper 4 out of 9 and against MW 4 out of 8, so I don't think it will have the desired effect.
PostPosted: Sat Dec 24, 2011 1:50 am
Oops..for some reason I thought that Sniper only applied to infantry. Point taken.
PostPosted: Fri Jan 06, 2012 12:52 pm
On an abstract level, the extra attack will marginally discourage the enemy from singling that stand out in combat (in preference to others), which rather nicely represents the defensive improvements a Dire Avenger Exarch in 40k provides to his squad (viz. Shimmershield, Defend), as well as the pure killiness he adds (diresword, power weapon etc.), so I don't have a problem with it as it stands.
Industrious, red-robe wearing member of the PCRC
