question: Firestorm numbers?
 Post subject: question: Firestorm numbers?
PostPosted: Tue Jan 11, 2011 5:13 pm
This question just cropped up during a game.
Why do Swords of Vaul need 2 firestorms in the formation? Eldar aren't short of AA already and not many army lists get 2 in a single fm. It's not like the SoV need more firefight dice. So what is the reasoning?
cheers
 Post subject: Re: question: Firestorm numbers?
PostPosted: Tue Jan 11, 2011 5:38 pm
Can't the IG take 3 hydras in one formation? Orks can certainly overload on flakwagons. Marines can only take one hunter per formation, but it takes 2 BMs to suppress them.
I don't think the eldar NEED 2 firestorms per formation, but I don't believe having the option is a game breaker.
PostPosted: Tue Jan 11, 2011 10:45 pm
I'd assume it's also got to do with upgrade options.
In addition to Semaj's points, a Marine Hunter can go in Tacs, Devs, or any Armoured formation. In Biel-Tan, Firestorms can ONLY go in a Sword of Vaul formation.
I agree with Semaj that I don't think it's necessary, but it'd make for more static lists, given the other AA options available to Biel-Tan.
Morgan Vening
PostPosted: Tue Jan 11, 2011 11:38 pm
I generally see and use two Firestorms in Falcon formations as the standard and most commonly used Eldar AA. Eldar do have good AA but that's one of their strengths and I think overall they're balanced fine.
PostPosted: Wed Jan 12, 2011 3:41 am
I think 2 in one formation and 1 in another is the most common only because GW sells them in packs of three.
PostPosted: Wed Jan 12, 2011 11:05 am
Could be worse Dobbsy, for a while there was a shield of vaul formation that was a combination of firestorms and night spinners, up to three of either!
PostPosted: Wed Jan 12, 2011 12:07 pm
Ah, I misunderstood the OP. The reason why is most likely a carry over from the original Falcon formation which allowed up to 2 firestorms. In development I think Eldar were (rightly) seen as being highly susceptible to aircraft with their low armor values and small formations.
